BlkCobra09
Old Jan 2, 2013 | 12:01 PM
rcook's Avatar
BlkCobra09
Anyone out there ever experiance engine light issues. Since upgrades my enigne light comes on about every 500 to 800 miles. My tuner DTC's indicates a lean condition and has been reset and checked by my upgrade supplier for whom i have confident in. He states its the gas the hi content of Ethanol in gas making the tuner setting above the set point of 93 octane. I recencly located a gas station that sells 93 octane gas without Ethanol content and will see if this problem persists.
thx.
Old Jan 2, 2013 | 12:04 PM
AlsCobra's Avatar
A Man Just Needs Some....
I wouldn't blame it on the fuel. Sounds like a tune issue that needs to be corrected. Lean is not good.
Old Jan 2, 2013 | 02:36 PM
Kevin509's Avatar
Agreed. Sounds like fishy reasoning from your supplier to me.
Are you using a tune from one of the major retailers like bama or is it a custom dyno tune? Ethanol in the gas shouldn't cause a lean condition.
Old Jan 6, 2013 | 02:31 AM
rcook's Avatar
Type SCT Custom Tuner, he states the ethanol content shows a highter octane level as times, I am tempted to go back to the stock tune and air box.
Old Jan 6, 2013 | 09:35 AM
Kevin509's Avatar
I understand that ethanol has a higher effective octane rating than normal gas, but the point remains that increasing the octane rating should not cause a lean condition. To run lean you're either getting more air than your tune is accounting for, or not delivering enough fuel, both of witch are tune related.
When I first installed my CAI before I was tuned I got a lean code a couple times because the engine was getting more air than the computer was accounting for. After getting a tune that took my intake into account I've never had a problem. The gas here has ethanol in it too....
Perhaps it would be helpful to list the mods on your car.
