Anyone use wheel spacers with stock wheels?
Considering getting some wheel spacers for my 2008 Bullitt, but not sure which ones would work best? Is anyone here running spacers with stock wheels? I'm thinking the car might look better with the wheels more flush with the wheel wells. Thoughts?
Some would argue against, some would argue for...
A small, say 1/4" to maybe 1/2" spacer, would probably not hurt. More than that might induce a look you do not like. Remember, the inner part of the wheel/tire is also moving out, and we don't really want you to have a roller skate look... do we? :) HOWEVER... You need to be aware that the wheels on the S197 (and many Mustangs) are hubcentric AND lugcentric. What this means is that the wheels fit onto the hub very precisely on a bit of the hub that sticks out, to center the wheel on the hub. This reduces vibrations due to the wheel being stuck out to one 'side' of the hub. As well, the lugs are tapered with the wheel, and that centers the wheel further. All to reduce vibration and the possibility of shearing the lugs on takeoff or heavy braking. So when you introduce a spacer, you may or may not induce a problem you didn't mean to. So get high quality, made for the specific application ones and not just whatever's on the shelf. And also be aware that the spacer may require you to also get longer studs lest you don't have enough threads on the lugs to secure the wheel. I would say that the right move is a wider wheel/tire with the correct offset, rather than to move the wheels out, but that's just me. I'm not saying don't. I'm saying do your research. Don't wanna have ya shear off any lugs or bobble down the road and spill yer drink, y'know. :) |
The only problem with a bigger wheel/tire combo is that I love the stock Bullitt wheels and would not want to change them for anything else. That's the main reason I'm thinking about spacers.
Originally Posted by mrp5150
(Post 6894027)
Originally Posted by cdynaco
(Post 6894030)
Patrick - laserred38 - used them on his SN95. He would know.
Patrick, I was thinking of these for the front and rear. The reviews all seem really good?
http://www.americanmuscle.com/eibach...chWheelSpacers |
(Post 6894053)
Patrick, I was thinking of these for the front and rear. The reviews all seem really good? http://www.americanmuscle.com/eibach...chWheelSpacers
(Post 6894079)
I'd give them a shot. I got some cheaper ones off amazon that were supposed to be CNC'd too, but you never know right? I didn't care for the vibration at higher speeds with the 1" bolt on ones on the front end - in both my applications the rear ends were fine. I even tried swapping them front to rear and one set was definitely more balanced than the others, but there was still a vibration. I'd think some brand name ones would be better...
(Post 6894172)
I'm guessing these Eibach ones wouldn't create a vibration? Or is there a different brand or size you would suggest?
Patrick, would these be alright or do you think they would create a vibration? They don't seem to have a brand name?
http://www.americanmuscle.com/1in-bi...l-spacers.html EDIT: Nevermind. Apparently these don't fit stock wheels. Wonder why? |
(Post 6894401)
Patrick, would these be alright or do you think they would create a vibration? They don't seem to have a brand name? http://www.americanmuscle.com/1in-bi...l-spacers.html EDIT: Nevermind. Apparently these don't fit stock wheels. Wonder why?
Maybe I will call American Muscle tomorrow and see which ones they recommend. I wish they made half inch or three quarter inch spacers. I feel like that would be the perfect size, but maybe the one inch spacers will be what I'm looking for?
(Post 6894517)
Eibach sells 20mm spacers and according to their website it should fit my Bullitt. Maybe those would look better than the 25mm ones? Such a hard decision.
Stick a ruler on the sidewall or rim to see how far those two would be out. If it's to better 'match' the wheel arches, that'd be the way find out. Perhaps more isn't better, or maybe it's just what the doctor ordered.
Eibach also sells a 15 mm spacer. Anyone running that size on a stock wheel?
(Post 6897324)
