5R55S Transmission issue
I posted this earlier in introductions by mistake. Hope this is the right place!
Hello my friends. I'm new to the mustang source and excited to hear from other mustang enthusiasts willing to share their mustang experiences.
I recently replaced the 5r55s transmission in my 2008 V6 Mustang. I ordered it through AutoZone as the price was OK and it has a good warranty. Took it to work and all worked fine going to work. Coming home going down the interstate with the gas petal constant, the transmission down shifted all by itself from 5th to 4th gear for no reason. A few seconds later the O/D light came on flashing. I immediately pulled over and shut down the car. Waited a few minutes, restarted the car and resumed down the road. All was OK then the car down shifts again, this time no O/D light. The transmission shifts fine going up to 5th gear but form some reason it does not want to stay there very long. Got it home, checked the fluid level, it was good.
Hint - The transmission seems to have no issues when its cold. This seems to happen after the fluid gets to temp.
Notes:
- No codes on the computer were registered.
- I flushed out the trams cooler when I replaced the transmission.
Possible self induced issues.
1. Linkage issue ?
Other possibilities
1. Possible torque convertor issue ?
Notes:
1. Linkage issue ?
Other possibilities
Received 1,556 Likes
welcome to the forum
I don't know ... but I wonder if it might be a tune issue? Perhaps the tune needs to be updated to properly control the new transmission? (Assuming it is a later model/variant than what you had before)
I was thinking the same. I did call a transmission repair and they said highly unlikely since I did not change the ECM but I think I'll do it anyway.
Thanks for your reply!
