Computer is slow only when on TMS
This is really getting on my nerves. Anytime I'm on TMS (which is a lot) my computer slows down dramatically when opening a new page.
At the bottom of the screen (where it tells you what's going on) first it tells me it's opening the page, then it tells me it's downloading the pictures, then it says it's "Building menu" This where it gets REALLY slow... when it's "builging menu". Takes about 15 sec for a page to load.
This is the only site that does this. It gets slower the longer I'm on here and even once I've closed all TMS windows, it seems to slow down other pages. The only way I can "reset" it is to reboot.
It's been doing this for several months and it doesn't do it on my computer at work. I've even recently reload Windows but the problem is still there.
Any ideas?
Any ideas?
hmm have you updated everything accordingly from windowsupdate.com or are you running something other than IE?
Scott,
Yes, I'm running IE and I've done all the updates. I have them set to auto so it updates about every other day.
Brad,
Any ideas on how to make it load faster? Like I said, it loads faster at work and that's a dial-up. Strange, huh?
Brad,
The Man... keeping you down.
Originally posted by StangNut@July 7, 2005, 1:43 AM
Scott,
Brad,
Scott,
Brad,
Click on Tools > Internet Options
When the Internet Options window opens, click on the Advanced tab.
Click on the Restore Defaults button. Answer OK or Yes to any questions then click OK on the Internet Options window.
Close IE.
Report status.
Before I do that, what specifically do you think needs to go back to it's default setting? I have a lot of settings in there I want to keep.
Is there a way to increase the amount of memory used for things like the Java menu?
Mine does the same thing. The window basically locks when it's in the "Building Menu" stage and if i scroll or click while it's doing that I usually get taken places I don't anticipate going, like different links, scrolling all the way down the page, etc. I'm on dial-up.
Specifically I am looking to see if the Java JIT compiler is enabled. If it is, try disabling it.
Or you could load FireFox and give it a try.
Originally posted by TheMustangSource@July 10, 2005, 10:59 PM
It's a JavaScript menu, not a Java menu. Similar names, VERY different technology.
That is why I recommend loading the SunMicrosystems Java packages, it knows the difference and will use the correct compiler.
Originally posted by Sendero@July 8, 2005, 1:45 PM
Open IE
Close IE.
Report status.
Open IE
Close IE.
Report status.
Didn't work.
Does it matter that when I first start reading TMS the speed is fine? It's only after being on here a while and reading several threads that it slows down. The longer I'm on (the more threads I read) the slower it gets. Once I restart the computer, it goes back to normal speed again... until I have been on here a while and it starts all over getting slow again.
Was that any help?
Originally posted by StangNut@July 13, 2005, 12:09 AM
Done.
Didn't work.
Was that any help?
Done.
Didn't work.
Was that any help?
http://www.mozilla.org/products/firefox/
Rinse and repeat.
Thanks. I downloaded it. It'll take some getting used to thoug. Several litlle things I don't like about it, but nothing major. I'll be able to find out tomorrow if it works. I'll let you know.
Off the subject, which is newer, Windows 2000 or Windows Milenium Edition? I'm trying to load Microsoft Office - Student. Says it will work with 2000.
2000 came out slightly afterwards.
2000 is built of the NT platform... Windows ME (Melinium) is built off the Windows 9x (95, 98) platform.
2000 is defintely better.
Rando
Sep 30, 2015 12:28 PM
lysingerjj
Sep 9, 2015 07:56 PM
