Wheel & Tire Fitment on air ride
I have a 2012 mustang GT...gonna purchase air ride & wheels & tires... looking for Wheel & tire Fitment on air ride...looking at this wheel & tire Package (made for my car but want to make sure to have no issues) with 20x10 wheels for front... with 275-35 tires... on rear will be 20-10 wheels... with 305-30 tires... will this setup have any issues on rubbing or any other problems on air ride... (& or on front rubbing issues... & rear hit my 3” exhaust or maybe the shocks etc) I heard on my year mustang (2012) 9” wheel is widest without any issues will there be any modifications if I run a 10” wheel on front
Thank you
Thank you
I do not think there is any difference between the 2012 and the 2014. From what I know the 2010-2014 are all the same setup. Only concern I know of is if you have standard brakes or the big Brembo brake. The Brembo brakes require difference rims for brake caliper clearance. I have a 2014 with Brembo brakes and I am running 20x9.5" rims all the way around with 275/35 tires on the rims. No rubbing issues with that size of tires. The 275/35R20 tires fit very nicely on a 9.5" rim. You really do not need a 10" for the front using that size. You will definitely need a 10" for your 305's on the rear set. The rim offset is very important, the Roush rims are a +45, which gives them the clearance needed for the big brakes. I do not have an air ride, but the car is lowered by 1.5". There are a few on here with air rides that will be able to give you a better idea of any special requirements. I know LaserRed38 had that on his car, you might shoot him a PM if he does not chime in.
Tire Fitment on bagged Mustang
l am leaning towards 20-10’s wheels... with +40 off set... 275-35 tires front... (or would 255’s be better) 285-35 rear (2012 mustang) on air ride... the wheel & tire only comes with 10 “ wheels... made for my 2012 Stang... just want to make sure 10’s will fit on front... without any issues... rubbing etc... 285’s on rear... also want to make sure no issues... on bags... will this set up have no issues???
