long time fan, first time caller
Old Sep 5, 2022 | 08:26 PM
Jennifer Wright Pittman's Avatar
Exclamation long time fan, first time caller
So, exactly one year ago, I replaced the struts, outer tie rods, control arms, and sway bar links on my 2008 Mustang V6. The only things I didn't replace were the inner tie rods because they looked okay. I still have the clunking noise in the front. At first I thought I didn't torque down the sway bar links to the struts. While I was under the car changing the oil today, I saw that the rubber of the outer tie rods were damaged. Could this be causing the the clunking noise? I wouldn't think it would be the strut mounts because I replaced the the entire assembly. I really don't know what else it could be. Also, can someone recommend a good company for the new outer tie rods I will have to buy? Thanks.
Old Sep 5, 2022 | 09:42 PM
05stangkc's Avatar
The Strut Mounts Have Been An Issue since Day One. I discovered when the Shelby Gt-500's Came Out That they were More Durable and the Way to Go. I can't Guarantee this is your Issue but If you Replace Them the Part Number is AR3Z-18183-A.
This is an Original Ford Part and Has a 2Yr Unlimited Mile Warranty. Outer Tie Rod Ends are DR3Z-3A130-A
In Fact Ford Racing Sold The Mounts and Stated Fits 2005-2008 Mustang and 28% Stiffer Than Mustang Gt Mounts M18183A {Back in 2007} Ford Racing Catalog.
Here is Latest Part Number Ford Racing Design Same as OEM I listed.
READ DESCRIPTION Good Info!
https://www.cjponyparts.com/ford-per...014/p/M18183C/
I show these Links For Info. Where You Buy Can Be Local or Other.
https://www.fordpartsgiant.com/parts...html?pnc=18183
FORD PARTS GIANT
https://www.rockauto.com/en/catalog/...rut+mount,7600
Rock Auto Has Motorcraft along with Generic. I only Know the Gt-500 Ones Held Up Better.
https://www.fordpartsgiant.com/parts...html?pnc=3A130
Tie Rod Ends FORD PARTS GIANT
https://www.rockauto.com/en/partsear...num=dr3z3a130a
Tie Rod Ends. MOOG is a Good Brand if you Don't Want Ford M/C.
Be Advised FORD & MOTORCRAFT are Same Parts Just Using Different Part Numbers.
{As Per Info Supplied this is my Best Answer.}
Don't Discount any of your Previously Replaced Parts as well. You Stated that you have already Replaced the Outer tie Rods and Already the Boots are Bad. I've seen Plenty of Bad out of the Box Parts and also early Failure Parts. In the Last Ten Years it got to be a lot more regular. In Fact I received New Strut Mounts from Ford Broken in the Box. They are Fragile Unmounted and Easily Damaged when Installing. Food For Thought.
KC
If you Scroll Down You Will See Similar Posts.
File Type: pdf
Old Sep 5, 2022 | 10:24 PM
m05fastbackGT's Avatar
If the tie rod bushings have any type of damage or are worn out, then yes, the tie rod ends can indeed cause your clunking noises... If you replaced the entire strut mount assembly, then it is highly unlikely the clunking noises are from the strut mounts... As for replacing the tie rod ends, I would order new ones from Ford if they're still in production, if not? then I would highly recommend checking out Steeda Autosports, Late Model Restoration or American Muscle... Links are attached below, if interested!
https://www.steeda.com/steeda-mustan...stang$253E2008
https://lmr.com/item/LRS-3130CB/2005...er-Tie-Rod-End
https://www.americanmuscle.com/musta...erod-0514.html
https://www.americanmuscle.com/sr-fr...link-0514.html
Old Sep 6, 2022 | 05:44 AM
Bert's Avatar
Welcome to the forum, as an official posting member ...
The clunk also might be due to the sway bar hitting the frame, below the radiator where it attaches with the two bushings. If the bushings are not "thick" enough to hold the sway bar out away from the metal supporting structure, you can get metal-to-metal contact. If that is the issue, I think new bushings might cure it; or you might need to put a small shim behind the bushing to push the sway bar out away from the support a little, to prevent that metal-to-metal contact. I hope that makes sense, I think I might have taken pictures of this but can't find them right now.
Old Sep 6, 2022 | 08:43 AM
05stangkc's Avatar
The clunk also might be due to the sway bar hitting the frame, below the radiator where it attaches with the two bushings. If the bushings are not "thick" enough to hold the sway bar our away from the metal supporting structure, you can get metal-to-metal contact. If that is the issue, I think new bushings might cure it; or you might need to put a small shim behind the bushing to push the sway bar out away from the support a little, to prevent that metal-to-metal contact. I hope that makes sense, I think I might have taken pictures of this but can't find them right now.
Good Area to Check for Sure!
Be Advised Ford Used Different Sway Bar Bushing Sizes and you will want to Specify those with a vin Number. The Rock Auto Site on those has Conflicting Info.
KC
Old Sep 6, 2022 | 02:43 PM
From what the OP described in her description, it would appear more than likely it's from damage to the outer tie rod end bushing that's responsible for causing the clunking noises
Old Sep 7, 2022 | 10:20 AM
Thank you everyone! I really appreciate all the tips. I will definitely be ordering new outer tie rod ends and I will look into the sway bar as well.
Old Sep 7, 2022 | 10:51 AM
05stangkc's Avatar
Let Us Know How it turns Out so it can Help Others!
Thanks,
KC
Old Sep 7, 2022 | 05:44 PM
We're always here and glad to provide support
Old Oct 3, 2022 | 06:48 PM
Angry The Saga Continues
Well, I replaced the outer tie rods and the inner tie rods as well since I already had them on hand. What could it hurt, right? I STILL have the clunking noise and it's ticking me off! Could it be the control arms? It clunks when turning and the road is bumpy.
Old Oct 3, 2022 | 07:08 PM
05stangkc's Avatar
Try This.
Get in Car Start up. From Center Crank Steering Wheel hard All the Way Right. Then Quickly Back to Center. See if it POPS! Then Do Same on Left Crank Hard & Quick to Left Hold a Sec. Back To Center See it It Pops! If So I Suspect Upper Strut Mounts.
Also If no Pop First Time Try Moving Car Forward Quick Jerk Accel. Move Like 2 Feet. Hard Brake Stop Neutral ,Turn Test Again. Still No Pop, Hard Reverse 2 Feet, Brake Neutral ,Turn Test Again.
Might Want to Try Turn Test With Hood Up and Somebody Listening Close to Side Being Tested See if a Noise Occurs on Top or Below.
Then See Post 2 If Pop Was Discovered.
Added Strut Mount PDF Install.
Lmk,
KC
Old Oct 10, 2022 | 06:16 PM
If its not coming from the sway bar end links? I would also suspect the upper strut mounts.. My advice would be to upgrade to OEM Motorcraft/GT500 strut mounts or order GT500 strut mounts from Ford Performance... The OEM 05-09 GT strut mounts are crap IMO!
Old Oct 10, 2022 | 06:59 PM
I think I’ve figured it out!
Replace parts I ordered are crap. When am I going to learn you get what you pay for? From now on, I will no longer order parts that are manufactured by TRQ or from 1A Auto. 1A Auto sent me replacement outer tie rods about a month ago (free of charge) and the rubber is ripping already. Aaannnnnd the linkage at the strut is damaged! I will be ordering from American Muscle from now on.
Old Oct 10, 2022 | 11:09 PM
Unless the parts you order from American Muscle are from established/well known brands? I wouldn't order anything from them either... There's a very good reason American Muscle hasn't been a sponsored vendor on this site for quite sometime now... If your searching for aftermarket parts from very reliable sources? I'd strongly consider looking into vendors such as https://lmr.com/2005-09-Mustang https://www.cjponyparts.com and https://www.steeda.com/steeda-mustan...-555-1053.html
Old Nov 4, 2022 | 05:56 AM
jemievardy's Avatar
Dan291
Aug 22, 2024 06:23 PM
Automatic 5.0
May 3, 2021 06:45 AM
SlowRiderr
May 2, 2013 05:54 AM
j0eyabs
Jun 21, 2012 10:11 PM
jcopin
Sep 23, 2010 05:06 PM
