I have a few issues first mustang i owned 2000 v6 fuel issues
After buying the car with about 165k on it automatic v6. Ever since i owned it the startup hot or cold was about ten seconds of cranking then stop then fires up on second turn over most times. So I knew the pump was bad so I just waited for it to go out, well first I changed the fuel filter and no improvement. I changed the spark plugs. The other day the rack and pinion cracked so bad where one of the fittings thread in the whole threaded part came off so as I had it on jacks over night I fixed it the next day no fuel...... I changed the pump and im getting spark and fuel at the rail. It will turn over forever and even start with starter fluid. It's my daily driver and my family depends on this car HELP PLEASE. ALSO WHENEVER I PUMP GAS IT LITERALLY BACKFLOWS SOMETIMES LIKE 12 INCHESOUT OF THE NECK WHILE IM PUMPING
