Présentation plus problème / Introduction With SJB / BCM Questions!
Bonjour à tous, Baptiste j'habite en France je viens d'acquérir une mustang GT de 2011 (rêve de gosse) , cependant elle a pris l'eau au niveau du BCM, plusieurs fonctionnalités ne fonctionne plus (phares, vitres, radio, ouverture de coffre, etc...) j'envisage donc de changer le BCM, savez vous si juste en le changeant ça va résoudre le problème ou si il faudra le reprogrammer ?
Merci
Merci
Hello everyone, Baptiste I live in France I have just acquired a 2011 Mustang GT (kid's dream), however it took on water in the BCM, several features no longer work (headlights, windows, radio, trunk opening, etc...) I am therefore considering changing the BCM, do you know if just changing it will solve the problem or if it will have to be reprogrammed?
THANKS
Welcome,
See Last PDF For SJB Install Process.
Also Here Are Some Threads Which Should Help Answer Your Questions. I Would Try Drying Out & Cleaning Connections First as Shown in Threads,
Also Shop Manual PDF'S See Below.
https://themustangsource.com/forums/...on-sjb-550481/
Although For Earlier Models This Would Be Good To Check as Well!
https://themustangsource.com/forums/...531649/index4/
At Some Point Checking The Body Codes Can Be Checked in Here. Also See PDF'S
https://themustangsource.com/forums/...e-info-550475/
KC
THANKS
Welcome,
KC
