SN95 with IROCS?
I'm sitting here at work bored and thinking about my mustang and also my camaro and I wonder how the iroc wheels would look on my sn95?
Don't banish me from the sight cuz I'm thinking blasphemy like that haha |
i think it could look kinda cool, in 17 or 18.
you would need to redrill your rotors/hubs/axles to get the chevy pattern though when im less lazy ill try and photoshop it lol |
I don't think it's worth trying to get them to fit unless they can be ordered with the correct bolt circle. But I am also the guy with lightning wheels on a Tahoe. :D
Well you'd have to get some adpaters to get GM wheels to work on a Ford. IIRC the Camaro uses a 5 on 4.75 bolt circle and Fords (very common I might add) is 5 on 4.50 (or 114.3 mm )
Then there is the whole offset issue and for a numbe rof years the 3rd gen F-bodies used the same size rim front to rear but different offsets - installing the rears on the front of the F-car would cause and inteference problem with the tie-rod ends preventing the wheels from turning at best or gouging the rim at worse and possibly damaging the tie rod ends - also the different offsets could effect the balance the wheel since the relationship between the balancer and the wheel has changed. |
