Mobil 1 0W20
Old Jul 16, 2008 | 02:25 PM
codeman94's Avatar
Mobil 1 0W20
http://www.mobiloil.com/USA-English/...l_1_0W-20.aspx
They say it gives you a 2% increase in mpg....but is it safe? both of my cars recomend 5W20. Just wanting to know if anyone is using it, and if they noticed a difference.
Old Jul 16, 2008 | 02:55 PM
Knight's Avatar
Needs to be more Astony
Mobil 1 has always made good stuff, but its also fully synthetic, you'd prob save more money buying regular oil and getting a little less mpg. depends on the cost of the oil i guess.
Old Jul 16, 2008 | 03:27 PM
codeman94's Avatar
I use Mobil 1 5W20 anyway...I guess I didnt think about the 0W20 being more expensive becuase it "saves you money."...Irony? I'll look at the price difference next time I'm shopping...
Old Jul 16, 2008 | 03:40 PM
Knight's Avatar
you run full synthetic in your cars now?
I don't bother in my focus, I run regular 5w20. changed the oil over the past weekend and 5qrt was only $9. plus $4 for the filter so $13 for the change not bad in my book.
Old Jul 16, 2008 | 06:33 PM
codeman94's Avatar
Yeah...its only about $25 per car with the full synthetic...and I go every 5K miles. Full synthetic just doesnt break down...
Old Jul 17, 2008 | 07:55 AM
Knight's Avatar
Every car these days should be every 5k, when i used to run full synthetic in my mustang i'd only do it every 10k miles.
Old Jul 17, 2008 | 08:05 AM
rhumb's Avatar
Probably does save a bit on mileage, lower friction and oil pumping losses and all. I'd be a bit nervous on a performance application, even given Mobil One's good reputation on this front, just seems a bit thin. My BMW M3 requires a special blend Castrol TWS at 10W60 and you can guess that it costs an arm and a leg ($10-$12 a quart, Tiffany's decanter not included, but cheaper than a $10K-$12K new S54 motor.)
Old Jul 17, 2008 | 08:19 AM
Indystang's Avatar
The "0w (winter)" means there is no resistance to flow at a cold temperature as compaired to room temperature (something like 70 not sure the actual numbers). Synthetic doesnt thicken up as it gets cold like regular motor oil. The "0" doesnt mean its thinner than the 5w or even 10w just the flow reading that it registered at cold. The high number 20 or 30 is the thickness at operating temp and will affect mileage. Go as low as you can on the first number if you live in an area that gets cold.
CoyotePremium13
Sep 23, 2015 06:45 PM
CoyotePremium13
Aug 18, 2015 07:28 AM
