Would HID lights look good on a GT?
Old Aug 25, 2007 | 09:51 AM
Emperor008's Avatar
I'm confused. The HID lights are nice, but are they only for headlights or foglights as well? If you drive with both heads and fogs on (like I do) and the head lights are HID, wouldn't that ruin the symmetry between the two lights?
Old Aug 25, 2007 | 09:58 AM
slipnotovk's Avatar
i say, get the CDC Billet Aluminum Grille and get the HID's. plus the HID's are so friggin bright as they are, you probably wont even need the fogs. but yea, if u do swap out the old halogens on the reg headlights and not the fogs, there will be a contrast but like i said, u prob wont even use the fogs anymore
Old Aug 26, 2007 | 12:53 PM
Artmx47's Avatar
a
In my personal opinion the yellow fog lights makes the overall appearance
so i suggest that you get HID all around...
and by the way, I have HID in both fog lights and headlights and the fog lights are brighter
Old Aug 26, 2007 | 02:34 PM
krnpimpsta's Avatar
yeah.. i have stock HID's (white) and stock fogs (yellow)... they don't look good together. too cheap to go HID fogs, but i'll probably end up upgrading the fog bulbs to a higher temp halogen to match.
Old Aug 26, 2007 | 02:59 PM
titanjc's Avatar
Do you have any nighttime pictures of the factory HID setup with the fogs on? I'm curious to see what it looks like.
Old Aug 26, 2007 | 07:35 PM
krnpimpsta's Avatar
yeah sure, i don't have a digital camera, but i'll take some tomorrow night when i borrow a friend's camera.
Old Aug 27, 2007 | 03:30 PM
mrkabc's Avatar
It won't match. I tried...
Just man up and get the HID lights for the fogs.
Old Aug 27, 2007 | 07:51 PM
randy_tho's Avatar
Will be interesting to see. What kit did you get for the fogs?
Old Aug 27, 2007 | 10:40 PM
krnpimpsta's Avatar
aight, took some pics, but i don't have the right cable to get it onto my computer. attempt #2 tomorrow.
Old Aug 28, 2007 | 07:38 PM
krnpimpsta's Avatar
Ok, uploaded. These are factory HID's and factory fogs.
Attached Thumbnails Would HID lights look good on a GT?-hidfog1.jpg   Would HID lights look good on a GT?-hidfog2.jpg
Old Aug 28, 2007 | 07:43 PM
ShowGT's Avatar
Not too bad but maybe some silverstars in the fogs?
Old Aug 28, 2007 | 08:04 PM
titanjc's Avatar
That does look kind of strange, because with the front markers, you have a total of 3 different color lights up front... I would either drive around with the fogs off, or go with HID's for them as well. Kits can be found on Ebay for ~$150 I believe.
Old Aug 28, 2007 | 08:10 PM
uofh2005's Avatar
Think the main problem is that the fogs are up at top and as large around as the headlights. If you look at pretty much all luxury cars with hids and fogs the fogs are halogen or some form of yellower/white output. Its just doesnt stick out as much since they are pushed lower on the car and smaller.
Old Aug 28, 2007 | 10:45 PM
Emperor008's Avatar
Thanks for the pics Steve. I really don't like the symmetry between the lights, but the HID's do look really nice. Would silverstars in the fogs actually do the trick, or is an HID fog kit the way to go?
Old Aug 29, 2007 | 06:47 AM
metroplex's Avatar
LEDs >>> HIDs. HIDs are so 1997.
Old Aug 29, 2007 | 06:51 AM
krnpimpsta's Avatar
No idea. I'm going to try out some higher temperature halogens on the fogs first and see how it turns out... I hate the mismatch too. Then, if that doesn't work, I'll probably try the ebay HIDs like titan suggested.
Old Aug 29, 2007 | 06:53 AM
krnpimpsta's Avatar
Oh, not only is it ugly, when I drive with them on, everyone REALLY thinks I have high beams on (I guess they assume the yellow = driving lights and glaring white = high beams). I've been flashed twice since I got this car last Thursday..
Old Aug 29, 2007 | 10:07 AM
YaoNYC's Avatar
leds are amazing but way too expensive and run very hot...
HID is good enough for the $
Old Aug 29, 2007 | 10:40 AM
metroplex's Avatar
HIDs used to be ultra expensive, and the Ford HIDs don't even use aspherical projector optics which is why they're so inexpensive.
LEDs actually put out a LOT more light when it's cold outside, so at night in the summer and at night in the winter, they're going to be more than adequate. They aren't affected by vibration or shock or even moisture. As an interim solution, HIDs are pretty appealing to most people. I'll stick with halogen until LEDs hit the market.
Old Aug 29, 2007 | 11:17 AM
YaoNYC's Avatar
that is definitely an option to wait. for most waiting a few years is way too long! haha
HIDs just look so much better than halogens and use less watt...and its almost pocket change to get it now.
do you know who sells LEDs now? if so how much? $1000+?
i did a search on google and i cant find anyone. thanks!
