Who uses ramps to work under their car?
Old Aug 6, 2010 | 03:03 PM
cmg06s's Avatar
Who uses ramps to work under their car? I have a new exhaust system to install and want to get some ramps to raise the back end of the car. Who uses them, what brand, and where did you get them from? I saw a nice plastic set at Autozone, I’m just worried that I won’t have enough clearance to drive the back wheels up onto the ramp.
Old Aug 6, 2010 | 04:00 PM
05RedGT's Avatar
I've got a set of the Rhino ramps and they work great. I have had the back of the car up on them.
Old Aug 6, 2010 | 04:03 PM
TTS197's Avatar
What part of the exhaust are you swapping out?
Old Aug 6, 2010 | 06:18 PM
cmg06s's Avatar
Just the axlebacks.
Old Aug 6, 2010 | 06:40 PM
colbymh's Avatar
Rhino I think are some of the best. Too quick of an angle for me to use. I just jack it up then put ramps under. Although I did make my own set out of wood. Just heavy to maneuver around.
Old Aug 6, 2010 | 08:38 PM
07S197's Avatar
Swamp Donkey Man Cans
I use ramps like these. I forget where I got them from but they work quite well.
Old Aug 7, 2010 | 06:30 AM
bob's Avatar
bob
Just the axlebacks.
No problemo even with the car on the ground. Its like a 30-45 minute job depending on the type of muffler your intalling.
Old Aug 7, 2010 | 06:32 AM
bob's Avatar
bob
Try moddifying the approach to the ramps, a trick I use is stacking some wood leading up to the ramp - One of these days, I'll get all fancy and make some stacked 2 x 12s just for the job.
Old Aug 7, 2010 | 10:28 AM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
Whenever I use ramps, they're Rhino.
Old Aug 7, 2010 | 05:36 PM
cmg06s's Avatar
Really? Im putting on Magnaflows. I would think it would be a little bit tight, no?
Old Aug 7, 2010 | 08:30 PM
area5179's Avatar
i use my Rhino ramps all the time when I change my oil. they work great. I also used them when I put on my SLP Loudmouths. They made things so much easier.
Old Aug 7, 2010 | 08:43 PM
2005GTDELUXE's Avatar
I am getting ready to get a set of raceramps.
http://www.raceramps.com/
Old Aug 7, 2010 | 09:00 PM
I started with Rhino ramps but they tend to slide so I have since moved on to driving up onto a 2x12 and then jacking the car up and onto the Cribs made by race ramps. Gives me the most room and work great! Next I'll go for a 2 post lift when I can finally get my shop built.
Old Aug 7, 2010 | 10:04 PM
D'prived's Avatar
I use a floor jack and jack stands.
Old Aug 8, 2010 | 10:00 AM
that sounds good.
Old Aug 8, 2010 | 05:28 PM
bob's Avatar
bob
Shouldn't be, I've done Flowmasters which wasn't hard at all, and of course the Loud Mouths on my GT500 were even easier. the hardest part IMO was getting to a set of bolts on top of each of the factory mufflers otherwise easy stuff.
Old Aug 9, 2010 | 09:44 AM
1chocophile's Avatar
Rhino ramps for me. I think I bought them at Wally World.
Before the Rhinos, I had a set of yellow metal ramps. They did not fit under the front bumper of my previous '99 'Stang or the current '09.
Old Aug 9, 2010 | 04:32 PM
Ministang's Avatar
I've had those same ramps for close to 20 years. Donn't care for them so much anymore, as they slide around too easily in my garage which has a racedeck tile floor. Now I just use a homemade set of short ramps for most tasks which I made out of a couple of pieces of 2x10 lumber.
The first time I swapped mufflers I did it without the car in the air, and it was pretty easy, but it took a good bit longer than when I've done it since with the car 3-4 inches higher in the air on my homemade ramps. They work well for oil changes too.
Old Aug 9, 2010 | 04:46 PM
karman's Avatar
Cool
I use floor jacks and ramps.
I am usually alone and I don't trust driving up ramps without a spotter. (or with a spotter really)
I just jack it up and drop it on my big metal cross-braced ramps.
Can't tell you what kind they are 'cause they are probably older than most of you are.
If I put the other end on my jackstands, I can get the whole thing off the ground.
Old Aug 9, 2010 | 05:36 PM
SteelTownStang's Avatar
Rhinos...
