Wheel hop
Old Nov 16, 2007 | 07:01 PM
medieval's Avatar
Wheel hop
I am putting my Roush in storage NOW what do I have to do OR buy to stop this F&^%* WHeel hop? So when spring comes I can deal with other issues....
Tanks
Everythime I get on it out in the country roads it starts this shi%
Old Nov 16, 2007 | 07:27 PM
theedge67's Avatar
Aftermarket Lower Control Arms will take care of most of the problem. Try those first, if that isn't enough, you may need upper control arms as well. Look into BMR, they are reasonably priced and fairly easy to install so I've been told.
Old Nov 16, 2007 | 08:01 PM
enitalp's Avatar
I have a upper control arm (no adj as i'm not dropped). and lower control arm. and i have no longer any wheel hop. it change the car a lot.
Old Nov 16, 2007 | 08:32 PM
chrisc9867's Avatar
you can get adjustanble LCAs along with a relocation kit if you are dropped. check out steeda
Old Nov 17, 2007 | 06:38 AM
medieval's Avatar
I looked at BMR I think I will go with the Level 2 kit. Thanks for the info guys.
Old Nov 17, 2007 | 09:23 AM
1550GT's Avatar
Other ones to check out would be J & M, (the ones I have) and CHE.
That gives you a couple more options. J & M are found @ hotpart.com.
Old Nov 17, 2007 | 07:17 PM
AGBULLIT's Avatar
http://www.steeda.com/products/stop_the_hop_s197.php
Old Nov 17, 2007 | 07:48 PM
Shelby10''s Avatar
Any aftermarket lower controls arms should take care of the wheel hop. If you are lowered I would get some LCA relocation brackets (aka anti-squats). An adjustable upper control arm should compliment this setup nicely. YOu want either an adjustable upper control arm and fixed Lower control arms. OR adjustable Lower control arms and a fixed Upper control arm. You want some adjustablility.
Old Dec 4, 2007 | 07:16 PM
medieval's Avatar
Ok so I looked at the CHE ones for 138.00 and the Steeda ones for 210.00 why is there such a price differance? Oh and I am not dropped.
Old Dec 4, 2007 | 07:24 PM
Mustangfreak's Avatar
Steeda is REAL proud of their stuff.
I have BMR fixed LCA's with poly on both ends, and an adjustable UCA with poly as well. 0 wheel hop.
Old Dec 4, 2007 | 07:37 PM
medieval's Avatar
So you mean that the CHE ones are junk? (sorta speak) I don't want to get adjustable ones If I don't have to. I trying to do this with min effort and tools. Or I will have to take it to my Roush dealer and have them do it. So I figured if I get the non adjusting kind it should be a no brainer. And yes do one side @ a time.
Old Dec 4, 2007 | 08:31 PM
I'm not saying CHE is junk. They make **** good stuff. Steeda is just super proud of their stuff, IE, wanting too much.
BMR and CHE are fine choices. But I'm not saying Steeda isnt. But why pay more when you can pay less and have just as good quality.
If you arnt going to drop your car, fixed will do the job. Hell, I installed my fixed LCA's, and ran with those for months, and still had no wheel hop. My UCA was just sitting in the box (ordered them at the same time) and I Was bored one day so I installed it.
So if you want to just do LCA's right now, you'll eleminate the wheel hop. And you can do it yourself, its super simple!
Old Dec 4, 2007 | 08:54 PM
Stoenr's Avatar
Like others have mentioned, LCA's
I have the che Adj. and have no more wheel hop. I did get a little at the strip on one launch, but Im pretty sure I farked that up considering the times I ran on that run, lol.
But other than that, no issues. previously it seemed the type of pavment you were on played a larger roll. Installed roush rear springs only and most of it seemed gone, but not all. added the LCA's and now it seems all to be gone.
Old Dec 5, 2007 | 08:09 AM
medieval's Avatar
Thanks, Mustangfreak & Stoenr I will take your advice.
Old Dec 5, 2007 | 01:38 PM
theedge67's Avatar
Check out the J&M ones, I think the website is www.hotpart.com. Looks like a good piece.
Old Dec 5, 2007 | 05:23 PM
Stoenr's Avatar
I have the J&M panhard, no issues, looks like a good product. I had mine powder coated black.
JonathonK
Sep 24, 2015 06:31 PM
Steve@CJPP
Sep 15, 2015 06:20 AM
