whats required to put 05 mustang rims on a 99-04 mustang
Old Nov 20, 2011 | 03:34 PM
SilverSkoundrel's Avatar
thought i heard you had to get spacers or something to put rims of an 05-09 model mustang on a earlier model just curious. for a friend
Old Nov 20, 2011 | 04:08 PM
mustangGT90210's Avatar
I will buy Jack Stands!!!
Think they bolt right up, but sit further inside the fender because they have less offset
Old Nov 20, 2011 | 04:12 PM
So spacers is a yes so it doesn't look goofy
Old Nov 20, 2011 | 04:26 PM
it doesn't look terrible. The fronts rub at full turn also. I ran them on my 2k for a while. No one ever noticed.
Old Nov 21, 2011 | 05:19 PM
okay guys thanks
Old Nov 26, 2011 | 10:56 AM
Is 7/16" spacers enough for all the way around the car?
Old Nov 26, 2011 | 04:18 PM
houtex's Avatar
The offset of your car is 24MM. The offset of a S197 is 45MM. A difference of 21MM outwards from your car's.
21mm=2.1cm, which is not quite 1 inch difference, it's .827" difference to be almost exact. a 7/8" spacer is .875" off the hub, so you're actually going a little too far by .05" I don't think anyone will notice.
One thing you'll NEED to do, though, is replace the studs with 7/8" longer studs, or get the spacer that also has it's own studs, and you mount on your hub with lugs. Trying to use the shorter studs on your hubs will not be safe. It might *work*, but there's less 'meat' for the lugs to grab, and 7/8" missing from that is quite a bit.
Old Nov 26, 2011 | 11:26 PM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
Extended studs and open ended lugs!
Old Nov 27, 2011 | 07:59 AM
06 Screamer's Avatar
http://www.newtakeoff.com/mustang_13..._mustangs.aspx
Old Nov 27, 2011 | 09:30 AM
future9er24's Avatar
which wheels are you planning on? some of the newer style wheels are available specifically for the 99-04's offset. You can find em at americanmuscle. I think there was a thread about this in the SN95 section. it might even be a sticky
Old Nov 27, 2011 | 09:33 AM
These Ford originals but I'm not goin through the trouble, know anyone close to northeast Texas looking for these?
Old Nov 28, 2011 | 06:30 AM
those are nice looking Josh
Old Nov 28, 2011 | 08:13 AM
They are ive got some the exact size n style but black on my 05 from Americanmuscle
tukatz
Oct 13, 2023 10:01 AM
Warrior316
Jul 22, 2015 02:38 PM
AdPock
Jul 21, 2015 06:38 PM
Jul 20, 2015 06:26 AM
whowasthat
Jul 19, 2015 01:49 PM
