What Strut Tower Brace Will Work With Factory Plenum Cover????
All the GT500 STB did.. was put deep indentation marks on both sides of the hood liner, and would slightly contact the underside of the hood itself..
So I ended up removing it altogether..As I didn't want to take any chances in damaging my hood..
I have a Strange Development GT brace. It fits very well (clears by a mile) over the MAG plenum cover--only a slight intent on the hood liner.
I went with the Strange brace because I tried two BMR braces and neither fit on my 06 GT.
http://www.granatellimotorsports.com...10040small.jpg
http://www.granatellimotorsports.com...7-suhsmall.jpg
http://www.granatellimotorsports.com...7-duhsmall.jpg
http://www.granatellimotorsports.com...-STB0507-A.jpg
Pick your poison - all the GMS bars clear - call 805-486-6644 ext 11 for a super good price
I already bought a used ford brace from a friend, I appreciate your offer though I will be contacting you in the future when I get some extra funds. I wanna get some of your lca's and the fuel gauge adapter!!!
I ordered a GT500 strut tower brace and my hood will not close with it on. So if anyone has a car with an aftermarket hood I be glad to sell this one to you for $35 + shipping. I guess I will save up and get one from Granetelli, it looks better too and it actually fits!!
Rocky, jaco, and GAGT:
Did you try flipping the GT500 STB to see if one orientation would allow more hood clearance than the other? I did massive googling and found a member Paleoc on the shelby v6 site where he ran into some problems but said if he reversed the bar, it would fit but contact the V6's DIS coil packs. Our GTs do not have those coil packs so that wouldn't be a problem.
I sure did, and afterwards..the STB ended up, resting directly on top of the intake plenum cover.
On the other hand, reversing the STB.. may clear the hood, however you'll have to uninstall the plenum cover..As it will not clear at all..
Did you try shimming the rear of the reversed bar with washers (1 washer for each rear stud)? JLT said that is how they managed to install the bar.
Another guy said he installed it without any mods.
I honestly don't know, how that guy pulled it off with no mods..But I'll definitely be giving Jay Tucker, from JLT a phone call tomorrow.. to find out exactly what size washers he used..
Charlie, I just finished checking the clearance..After using several different washer combinations, the GT500 STB barely clears the intake runners, and hood without the plenum cover..
However, even with the bar reversed with washers..It clearly will NOT clear the intake plenum cover..
So my advice is this..If your looking for a STB to clear both the hood, and plenum cover..the GT500 STB, will NOT work with the stock GT hood..
On the other hand, reversing the bar will clear the hood..but again without using an intake plenum cover..
Anyway, my apologies for not being able to provide more encouraging results..
Will the GMS single STB clear the factory OEM Ford plenum cover w/o lowering, AND a stock 07 GT hood with hoodliner?
Do you have any close up pics of how the GMS single STB interfaces with the strut mount studs?
Although the GMS single bar, does appear to clear the plenum cover. It also appears very close to it as well..
What really concerns me is..if the bar is close enough, it wouldn't take much engine torque, in order to make contact with the plenum cover..
And if there's enough force behind the engine torque..It may also be just enough to damage the plenum cover..
I saw some pics of the GMS single bar and the holes that fit over the strut mount studs were wide enough that it wouldn't even brace the strut towers under load. The studs would simply shift through the STB holes!
Thanks for all the help Rocky, I appreciate you taking the time to check on everything I suggested.
Both your suggestions and advice, were very valuable Charlie..and even though the GT500 STB, won't clear both the OEM plenum cover and hood..
At least we now know, that by reversing the bar..will somewhat clear without a plenum cover..So at least it isn't a total loss lol.
The question is..will just under 1/2 inch above the plenum runners, be enough clearance..
IMHO, once you consider engine torque as a factor..it would seem that anythng under 1 - 1 3/4 inches, just isn't enough clearance.
#40
At least we now know, that by reversing the bar..will somewhat clear without a plenum cover..So at least, it isn't a total loss lol.
http://www.granatellimotorsports.com...lay.php?gid=28
