What is this gauge?
In the bright sunlight yesterday I took a look at the gauges on my 05...there is, on the RPM gauge side at 12 o'clock in the middle by the RPM numbers that looks like an "Up Arrow". Almost like a dummy shift light or something like that. It's never turned on or anything, I've just wondered what that was.
Thanks.
Thanks.
If it doesn't turn on when all the idiot lights go on when you start the car, I'd guess it isn't hooked up and just a light that is used on another vehicle.
From the placement you mention it does sound like a shift light. Nothing in the owner's manual about it.
Originally posted by mustp51@August 24, 2005, 8:19 AM
I've wondered about that one too.
This is the one you're talking about, right?
If its an up arrow...its probably a shift light....
It was on the original pics of the dash...but it always looked like it was taken out.
Wonder if its accessable from a ford dealers reprogramming...
Like how they can turn on/off Global Windows and the 'reverse notification beeping'
Originally posted by 05HawkeyeGT@August 24, 2005, 8:33 AM
Yup that's the exact one I was thinking about. It would be nice if you get activate that somehow, I wonder how the wiring on the back of that looks. By activating, I mean make it like a functional shift light...not the dummy light telling you when to get the best gas mileage, but an actual shift light when it's nearing red line?
Originally posted by holderca1@August 24, 2005, 8:58 AM
I'm not sure I follow, you need a light to tell you are nearing the red line? The red line is on there at 6k, shift before you hit it.
Yes of course it is easy to see the giant redline block on the RPM gauge in the 05's, I know where redline as I'm sure everyone here does, I'm not even saying I'd want to have it there even if I could enable it. But a nice bright light telling you right before you should shift in a drag racing scenario in a track could be beneficial.
Originally posted by softbatch@August 24, 2005, 9:15 AM
The only problem with this light is that it would probably not be bright enough to be able to see in your peripheral vision
Originally posted by Boomer@August 24, 2005, 9:46 AM
It'd be there for 'mileage' not 'drag racing'
Not sure but I think 169stang has wired a shift light in his car.
I have seen many drag racers have them. I hear it helps shift at a more consitant point as oppsed to just watching the RPM needle.
There is no LED behind it, for the 05'.
Probably not, but if there is no LED back there you should eb able to wire a shift light behind it to go off at a certain RPM. But another problem you run into is that the OEM Tachometers isn't as acuarate as the aftermarket tachs that people, hence the market for aftmarket tachometers.
Originally posted by Andy Haynes@August 24, 2005, 1:08 PM
That is the reason a shift light doesnt work off of your factory tacometer. You wire it in to work off of true rpm's .
So your saying that the light behind the cluster could just as easily be wired from the true RPMs instead of the Tach or would you need to have an aftermarket Tach.
What makes the tach not accurate? Why wouldn't they wire it the same as the aftermarkets?
mmmm... Taco Meatier
