Using mothers powerball for polishing stuff
Old Apr 27, 2006 | 03:07 PM
traffic142's Avatar
I was wondering if you or have you used mothers powerball or miniball for polishing some bright work on your car? I saw that someone had used polish on the rear diff cover. I figured that the mini ball would do it easier and then I thought about the valve covers or other bright work under the hood.
what do you think? [img]style_emoticons/<#EMO_DIR#>/dunno.gif[/img]
Old Apr 27, 2006 | 11:01 PM
Eleanor Dreaming's Avatar
I use the Powerballs to clean and polish my wheels. But, I 'm sure they are tough enough to take a none polished item all the way to polished. It is only a tight cell foam formed into a ball. The Flitz Ball is good to and a bit tougher.
Old Apr 28, 2006 | 09:42 AM
Donna's Avatar
Queen Of Nascar
I have the small one and it works great!! I've used is on my rims and my exhaust tips. The small one gets in between the rotors really good on my rims. It comes with a nice extender piece for hard to reach areas. I also love the Mothers Chrome polish and the mag & aluminum polish. Good Stuff!!
Old May 22, 2006 | 11:44 AM
official_style's Avatar
where do u get the mini? i cant find it anywhere!
Old May 23, 2006 | 05:54 AM
I got mine at Advance Autoparts and I have seen it at Autozone.
Old May 23, 2006 | 08:47 AM
INTRUDER's Avatar
The MOTHERS POWER BALL is made of a VERY soft foam,
while it is good enough to keep a polished item bright and shiny
it is NOT tough enough for hard poilshing.
I have a FLITZ power ball
http://www.flitz.com/
They have a deal for TWO power ***** and some polish.
And they have 2 sizes.
The Flitz is a pretty good product in its self...
My 2 cents
Old May 23, 2006 | 08:51 AM
adrenalin's Avatar
I am sure the powerball will fall apart if you are trying to polish dull metals or small pieces. I have the 6" powerball and it has started to fall apart and that is just from using it on my rims. The powerball-mini is made of the same material so I am sure the same problem would occur. I'd just get a polishing pad used for drills/grinders or use a dremel depending on what needed to be poished.
Infamous_blackbeard
Oct 8, 2015 10:45 PM
MustangConvert11
Sep 30, 2015 08:01 PM
14Glassback
Sep 11, 2015 04:50 PM
Sep 10, 2015 12:44 PM
