TSB # 05-09-15
FYI- the TSB sticky has info on most (if not all) of them...
Pasted from the sticky:
TSB
05-9-15
MIL AND ETC LAMPS ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
Publication Date: April 28, 2005
FORD: 2003-2005 Thunderbird
2005 Crown Victoria, Mustang
2004-2005 Explorer, F-150
2005 E-Series, Expedition, F-Super Duty
LINCOLN: 2003-2005 LS
2005 Town Car, Navigator
MERCURY: 2005 Grand Marquis
2004-2005 Mountaineer
This article supersedes TSB 04-21-09 to update the vehicle lines and model years.
ISSUE:
Some vehicles built 11/29/2004 and prior, may exhibit the malfunction indicator lamp (MIL) and electronic throttle control (ETC) (wrench) lamp on with both P2106 and P2135 diagnostic trouble codes (DTCs).
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration using WDS release B36.11 and higher or B37.2 and higher. This new calibration is not included in the B37 CD. Calibration files are also available at www.motorcraft.com. Replace the throttle position sensor (TPS) following the instruction sheet included in the TPS service kit. Clear all DTCs. If the condition is not corrected continue with normal diagnostics.
CAUTION: FAILURE TO FOLLOW THE TPS REMOVAL AND INSTALLATION PROCEDURE WILL RESULT IN DAMAGE TO THE TPS SCREWS.
LABOR OPERATIONS CLAIMING CHART
Operation Labor Operation Application Time
050915A Check For Codes, Reprogram PCM, 2003-2005 LS 3.9L 1.4 Hrs.
Replace The Throttle 2003-2005 LS 3.0L 0.7 Hr.
Position Sensor, And 2003-2005 T-bird 3.9L 1.4 Hrs.
Perform Final Quick 2004 Explorer 4.0L 0.6 Hr.
Test (Do not use 2004 Explorer 4.6L 0.7 Hr.
with: 12650D, 12650D84, 12650D1, 12650DX1) 2005 Explorer 4.0L And 4.6L 0.7 Hr.
2004 Mountaineer 4.0L 0.6 Hr.
2004 Mountaineer 4.6L 0.7 Hr.
2005 Mountaineer 4.0L And 4.6L 0.7 Hr.
2004-2005 F-150 4.6L 0.6 Hr.
2004-2005 F-150 5.4L 3V 0.7 Hr.
2005 Mustang 4.0L 3V And 4.6L 3V 0.7 Hr.
2005 Crown Victoria 0.7 Hr.
2005 Grand Marquis 0.7 Hr.
2005 Town Car 0.7 Hr.
2005 F-Super Duty 5.4L 3V And 6.8L 3V 0.7 Hr.
2005 Econoline 0.9 Hr.
2005 Expedition 5.4L 3V 1.0 Hrs.
2005 Navigator 5.4L 3V 1.0 Hrs.
PART NUMBER PART NAME
3L5Z-9B989-AA TPS (Kit)
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
DEALER CODING
BASIC PART NO. CONDITION CODE
RECALEM 04
TSB
05-9-15
ISSUE:
ACTION:
WARRANTY STATUS:
DEALER CODING
RECALEM 04
I saw that in the TBS section, i was just wondering why it would show up on an Oasis read out on a car that was built Friday 5/6 ?
Fritz "05" Silver GT Coupe built 5/6 .....
southern stang
7/17/15 11:47 AM
