Tire pressure on wider tires
Old Aug 22, 2016 | 03:32 PM
Left Lane Muscle's Avatar
Hey guys, I have 275/40/18 up front and 295/45/18 in the back. What pressure would you guys recommend I keep them at? Thanks
Old Aug 22, 2016 | 04:47 PM
redonblackpony's Avatar
If it's only Street driving, fill to recommended by the tire manufacture. Most likely it will be 35 PSI-40 psi
Old Aug 22, 2016 | 05:55 PM
Thanks for the answer man. Will do
Old Aug 22, 2016 | 06:07 PM
PJRManagement's Avatar
Currently a Corvette Owner!
35psi for street.
Old Aug 29, 2016 | 12:32 PM
07 Boss's Avatar
Generally wider tires, given the same load, will require less air. lowering or raising air pressures will effect handling too. I run a 255/45 up front at 41 psi and a 305/45 in the rear at 28 psi. I would run the rears at like 24 psi but the pressure sensor doesn't like that. The harder front tire is to help with any tramlining or nibbling and the softer rear tire is help with traction. So I would follow the recommended pressures and adjust from there.
Old Aug 30, 2016 | 10:04 AM
m05fastbackGT's Avatar
I run mine between 32-35psi..
Old Aug 31, 2016 | 04:12 PM
Bert's Avatar
For the street, I would run them up fairly high like 35-40 psi like Redonblack said. This will reduce the rolling resistance a little for a hair better mileage. It won't give ultimate maximum performance, but you can't use that on the street anyway.
For the track, the "optimum" is probably much lower, like 30-ish . . . but that is best determined by adjusting the pressure based on the amount of sidewall roll-over that you are getting on hard cornering, which really can only be done on the track.
ebaG
Mar 25, 2022 05:36 PM
mikes70mustang
Custom Vanity Personalized License Plates & Brackets /Delete Brackets
23
Jan 19, 2017 12:55 PM
xunan
Aug 16, 2016 09:36 AM
SN95_fambam
Aug 9, 2016 07:08 PM
buckethead1
12
Jun 2, 2016 07:04 PM
