There's a power plug in the center console box?!
I've had my car for 3 months and I just realized there is a power plug in the center console box. I don't know why I just found it, but it's good news for me. Now I can stick my iPod FM transmitter in there and get rid of that awful sight of the wire I had to plug into my dash.
We wanted you to be clueless. BTW, you should get a head unit that supports an ipod interface cable. Or at least a head unit with auxiliary connections. FM transmitting is horrible=)
There is also a place to hold things on the bottom of the center console lid
So do you know you can at least remove the rubber insert in the cup holder to hold bigger cups
Carol inside the console theres a small cover for a plastic door that can be pulled off with your fingers (its that angled up piece on the drivers side) .it might help move the air through the console and not build up in the closed console box,if you want give that a try and see if it helps .
any static?
I use an IPOD FM transmitter and have no problems. I can choose among 10 different FM stations to set mine to. I don't remember which one I have but if anyone is interested just PM me and I'll look to see which one it is when I get home tongiht and get back to you.
Haven't seen that one before. Looks really cool. I have one similiar to that for my home use when I want to play my ipod through my home stereo (but that one looks better). The one I have in my car plugs into the power socket so it charges my ipod while I use it.. ipod battery life :notnice:
Originally posted by teddybear1255+May 10, 2005, 6:14 PM--><div class='quotetop'>QUOTE(teddybear1255 @ May 10, 2005, 6:14 PM)</div><div class='quotemain'><!--QuoteBegin-2005 Black GT@May 10, 2005, 7:39 PM
[/b][/quote]
Sounds like an Easy Bake Oven...I'll have to try baking a few things!
http://www.newertech.com/ipod
it's good for 21 hours. In real life use i've gone 1 to 2 weeks without having to charge my battery, they also have replacement batteries for later generations.
worth looking into if your battery is starting to fizzle out. It was easy to change for the 2nd gen also
I have the FM transmitter from Griffin Technologies. I like it, the sound is ok, and I like being able to use it in the car, or other people's houses, etc. I really do want to get a direct line set up for the new mustang though. I haven't found the right thing yet. Anyone know anything about the SiK imp?
http://www.ipodlounge.com/index.php/review...-line-out-ipod/
this has a charger and line out, but with the shaker 500/1000 there is no solution yet for ipod input except by fm transmitter
it doesn't look like it's compatible with the itrip which is what i assume you have.
05windveilbluegt Posted Today, 01:21 PM
which ipod do you have? I have the 2nd generation 20 gig and i put in a battery from this company
