Tank size
Old Oct 22, 2005 | 12:23 PM
Kevinicus's Avatar
Ok, had my car for about 2 weeks now. On my second tank of gas. I'm getting around 20 MPG on this second tank according to the dash. The dash also says I've used 12.7 gallons, and that I have about 47 miles to E. Doing the math, that's about a total of 15 gallons, not 16? Is it considered E when there is only one gallon left? Shouldn't it be about 67 miles to E if it had 16 gallons? And I'm sure the tank was full.
Old Oct 22, 2005 | 12:40 PM
jcopin's Avatar
its been 15 since i had my 96 mustang
Old Oct 22, 2005 | 12:44 PM
maucoin65's Avatar
Legacy TMS Member Retired
16 gallon tank. The fuel gauge is very accurate, 1/4 tank is right at 4 gallons.
The distance till empty is a constantly moving target, depending upon what you have been doing and how you are driving at the precise moment you are reading it. I have found the (12.7 in your case) gallons used to be very accurate. You really can't tell from tank to tank becaue there are too many variables. Set it and forget it for a month or 3, then see what your MPGs are for the car over time. That will give you more meaningful information than, say, how did I do today.
Old Oct 22, 2005 | 12:47 PM
Wardog 07's Avatar
I concur with Mike . . . miles to empty is dependent on how heavy your foot is. :drive:
Tom
Old Oct 22, 2005 | 12:58 PM
jcopin's Avatar
just checked fords website..sonofafemaledog its 16 =p
my 96 only went to 15 even after running out of gas =p
Old Oct 22, 2005 | 01:33 PM
AWmustang's Avatar
i believe the miles to E also has a bit of reserve built in. Even if you drive exactly the same E will happen before you run out of gas completely.
Old Oct 22, 2005 | 03:16 PM
ponyboy66's Avatar
I have found it to be very accurate.
I have run down to 1 mile to empty and 2 miles to empty both times
the tank took around 15.3 gallons. A little reserve beyond 0 I guess.
Old Oct 22, 2005 | 03:51 PM
GRAYPNY's Avatar
Good topic, I was wondering about the tank size myself. I had the gas light come on today for the first time (I don't have IUP) and filled up with 13.725 gallons. I guess I had plenty left.
Old Oct 22, 2005 | 05:27 PM
Boltzman's Avatar
i still can't tell yet.however that dadgone reading that tells you how many miles per gallon you are getting drives me crazy.The first 3 weeks it read around 17.8 and this week iv'e been doing the exact same driving and now it 's been reading 16.0 Also hate how it keeps switching to certain miles to empty. :bang:
Old Oct 22, 2005 | 05:53 PM
Kevinicus's Avatar
Yeah, that is kind of annoying. I wish it would tell you once and be done with it until you get really low. I don't really need to know the fuel is "low" when I have 70 miles left, and then every time I start the car and a few other times in between.
I just filled the car up, just over 14 Gallons, dash said about 13.8/13.9 somewhere in there I think. Had the gas shut off problem, at least when I had the automatic thing all the way up, I put it down a notch and it filled up ok...though I think it spilled over a little bit. It overflowed a bit the first time I filled it up too.
So, I'm guessing it's pretty much got a reserve built in, so E isn't exactly empty, just "fill it up now please."
Old Oct 22, 2005 | 06:10 PM
firststang's Avatar
E is not empty, there is usually a full gallon or more when you're showing empty on the fuel gauge. All ford vehicles have similar tolerancing.
Old Oct 22, 2005 | 10:30 PM
PolkThug's Avatar
I ran my down to "0 til empty", and I believe it took 15 gallons. (I'd have to do it again to be 100% certain though)
Old Oct 22, 2005 | 10:39 PM
Sonic Brew's Avatar
I think I saw some where that its 15.7, I could be wrong though.
Old Oct 23, 2005 | 07:57 AM
Ballz's Avatar
Couldn't you just read the window sticker to get the tank size? Or perhaps the label on the driver side door?
Old Oct 23, 2005 | 08:10 AM
Badsnke98's Avatar
GT has always been 15.7 and the V-6 is 16 gallons.
Old Oct 23, 2005 | 10:03 AM
Boltzman's Avatar
I have the 06 tung vert and thought the fill up problem would have been resolved.not for me :angry: taking it in to get new tank on the 31st
Old Oct 23, 2005 | 10:16 AM
traffic142's Avatar
I cannot get above 16.9 mpg. I ride on a trip and do really well not getting on it. but then I am in town and well, we all know what happens at red lights and such.
oops there goes my mpg again
Old Oct 23, 2005 | 10:59 AM
maucoin65's Avatar
Page 221 of the 2005 owner's manual says 16 gallons (60.6 liters), all applications (i.e. V6 and V8).
Old Oct 23, 2005 | 05:29 PM
AWmustang's Avatar
My focus always had the gas light turn on when there were 3 gallons left. Sounds like your mustang is the same.
Old Oct 23, 2005 | 11:01 PM
clockworks's Avatar
Ok, get this. I reset all my info center stuff everytime I get gas. One time I was looking at it and it said 1.0 gallon's used, 16.4 miles on the trip meter, but my MPG reading was 15.1. WTF?
I mean seriously. The "gallons used" meter should be very accurate. The odometer reading should be *exact*. How hard is it to make the MPG reading accurate? All you do is take the trip meter reading and divide it by the gallons used meter. The MPG reading should do that every 10 secs or so.
Of course that is granted that you have separate meters for everything. I mean, when you restart your MPG meter, it should have its own trip meter and its own gallons used meter that is independent of the other ones in the info center.
