Take off the clips on the wheel studs?
Old Nov 17, 2007 | 11:21 PM
jmanpatsfan's Avatar
I am doing some wheel work and I am wondering if I should take off those clips that are on one of the studs for each wheel.
Old Nov 18, 2007 | 02:38 AM
scramblr's Avatar
They were only put there to keep the rotors in-place through the factory line. You can take them off. If you go with aftermarket wheels, they have been known to cause vibrations due to the wheels not being seated right.
Old Nov 18, 2007 | 04:08 AM
For reference, incase others are wondering what the heck we're talking about...
Old Nov 18, 2007 | 08:24 AM
scramblr's Avatar
Leave it to Bill to have a pic...
Old Nov 18, 2007 | 09:55 AM
Fryguy's Avatar
That is the truth!
Old Nov 18, 2007 | 08:40 PM
Fastrack's Avatar
Not to hi-jack the thread but it's kind of related. What ft-lb torque should the lugs be on the standard 17" 2005 GT rims ?
Old Nov 18, 2007 | 09:00 PM
What exactly do you mean, I just tighten them until they dont turn anymore.
Old Nov 18, 2007 | 09:05 PM
wallace's Avatar
100lb-ft, pg. 173 owners manual.
Old Nov 18, 2007 | 09:35 PM
scramblr's Avatar
You can warp your rotors by doing that. Best thing to do is tighten them in a star pattern to 100 ft lbs.
Old Nov 18, 2007 | 10:19 PM
I completely dont understand.
Old Nov 18, 2007 | 10:22 PM
n8rfastback's Avatar
its easy, take a pen, draw a star......
thats the pattern you should follow...
just dont go from one stud to the stud next to it, to the stud next to it... etc
do not go in a circle pattern when tightening them.
Old Nov 18, 2007 | 10:30 PM
so do i need to go out and buy a torque rench.
scramblr's Avatar
Here, try this pdf. And if you're going to be doing any work on your car yourself, yes, a torque wrench would be a good idea.
File Type: pdf
Old Nov 18, 2007 | 10:33 PM
i dont use a torque wrench on mine....
tighten them down good and snug, but not too far or they will be really hard once you try to take them off.
kind of like the oil filter.... tighten until snug, then tighten them another 1/4 turn (or so)
or get a good torque wrench and do them to 100 ft-lbs
Old Nov 18, 2007 | 10:51 PM
I just read up a bunch on this. This is the second time my wheels are off, the first for the calipers. When I re-mounted the wheels, I made the lugs extremely tight (I am compulsive in this matter, as well as I didnt think there could be any consequence besides trying to get them off again.) Well this time when I took the wheels off, I had no problem loosening the lugs. Is it possible that the recommended torque values are now skewed due to the fact I made them really tight before?
Old Nov 18, 2007 | 11:08 PM
scramblr's Avatar
Lugs can get loose over time. It is recommended to check them one week of driving after install and then at least once per month.
Old Nov 19, 2007 | 06:50 AM
Fastrack's Avatar
I never even thought of checking that Thanks..
I know about the star pattern etc..
Old Nov 19, 2007 | 07:27 AM
I never thought about them working themselves loose. And definately dont tighten them as tight as you can, I've seen lugs break, and know that rotors will warp.
Old Feb 6, 2012 | 06:18 AM
whokilledkaji's Avatar
I just got a set of 18" SVT Bullitt wheels for my 2011 Mustang and was told to remove the stud clips as well... So, they just pull off?
Also, I'll switch back to my 19" nickel luster wheels when summer comes, so will I need to put the clips back on?
Anything to be aware of?
Thanks for the helpful thread!!!!
Old Feb 6, 2012 | 08:13 AM
Sabre's Avatar
No....remove the clips, throw them in the trash can and don't ever think about them again. They are put on during the manufacturing process, so the rotors don't fall off, as the car moves down the production line, before the wheels are put on the vehicle.
