The stock one looked so plain
Old Feb 8, 2008 | 01:18 PM
Va Stang's Avatar
and the strut brace had rubbed the paint. I would like to buy a custom airbrushed plentum cover. But the $400 plus price tag is a little hard to swallow. So I figured I would add a little color to this one for about $15 bucks instead. Goes much better than the OEM silver and gray.
Old Feb 8, 2008 | 01:24 PM
n8rfastback's Avatar
wow thats an improvement!!!!
Old Feb 8, 2008 | 01:39 PM
Bluesilentpro's Avatar
Yeah that ist great! Man this is perfect for a vista blue Stang..
Old Feb 8, 2008 | 02:22 PM
302svt's Avatar
That looks great, how did you paint the blue, with a brush or spay can.
Old Feb 8, 2008 | 07:47 PM
That looks excellent!
Old Feb 8, 2008 | 09:17 PM
05RedGT's Avatar
I'm going to have to repaint mine as well because the hood liner has rubbed on it. Need to get a strut brace too to keep the hood liner off the cover.
Old Feb 9, 2008 | 07:05 AM
Marin7076's Avatar
How did you do it? - looks great
Old Feb 9, 2008 | 07:48 AM
DarkFireGT's Avatar
We definitely need more pics and info.
Old Feb 9, 2008 | 08:12 AM
ufnavy06's Avatar
....+1
Old Feb 9, 2008 | 12:15 PM
colbymh's Avatar
Looks GREAT!!!
Old Feb 9, 2008 | 01:46 PM
Robbieg's Avatar
Great job!
Old Feb 9, 2008 | 05:45 PM
Poco's Avatar
The paint looks translucent,very cool effect.
Old Feb 10, 2008 | 05:02 AM
MUSTANGLOVER73's Avatar
sweet!!!
Old Feb 13, 2008 | 10:53 AM
Va Stang's Avatar
All I did to paint was first pull the pony off. Used a hair dryer to heat and took my time . It is just glued on with foam tape the entire surface.Ruff up the surface with a scotch brite pad. Make sure to get the curves and inside tight spots. Washed with soap and water. Dry well. Painted with plastic primer adhesive. Used 3 to 4 light coats.
Then I painted with flat black. Sprayed 3 to 4 coats starting out with a light coat and finishing with a med. wet coat. Let dry over night. Tape off cover with low adheasive tape. Make sure to get as close to the letters as possible, even in between them at the wider areas. Cut pieces of paper and run between ribs. I got lucky and had a old roll-up calendar that when seperated the pieces fit between the ribs.
I bought a couple mimi foam rollers Wal-mart). Bought heavy metal flake blue paint from auto zone. Sprayed foam roller then rolled ribbing and lettering. Roll an area only once or it will pull away as it dries and you roll back over it. Took several series of spraying and rolling to finish. I would put the roller in a plastic bag in between drying times so it would not dry out. Let dry remove tape and glue the pony back in. You can clear coat if you like. Here's a shot of it in the engine bay. Its a little dirty. I have not cleaned it in a while.
Old Feb 13, 2008 | 12:57 PM
That looks great.
Jim74656
May 1, 2023 02:15 AM
FarmAnimal
Aug 3, 2015 05:53 PM
mark0006
Jul 30, 2015 08:08 PM
