Steering Squeel
Old Aug 28, 2006 | 10:28 AM
NJCoastFlyFish's Avatar
Steering Squeel
Thought I should mention that I had a problem with the steering making noise when the wheel was turned only after the car was warmed up. I tried putting in more fluid but that didn't do anything. After I brought it to the first dealer they had my car for two days and all they did was claim to "tighten a tensioner" and that the noise was gone. After I drove it home the problem seemed to be gone, then the next day it was back.
Dealer number two had 100% better customer service and fixed the problem in a matter of hours. They said they had to take the whole steering rack down and relubricate the "boots." Now a week later the steering is still quiet, thought I should share what fixed the problem just incase it happens to someone else
Old Sep 8, 2006 | 12:05 PM
Mtang78's Avatar
Did this noise happen only when you were actually moving - turning or could you be sitting still and turn the steering wheel and it squeal? They couldn't find any problem with mine and so several months later I still squeal. Really annoying seeing as how it is now out of the 36,000 mile warranty. It seems that when enough people have the problem they identify it and will fix it under warranty but if you were one of the "lucky" people to get one of the '05s built in the first quarter of production then you are going to be SOL because you won't have any warranty left by the time they find a solution you have complained about since the get-go.
Old Sep 9, 2006 | 02:22 PM
Realdeal's Avatar
I had the problem it would make a kind of whirring noise that sounded like it was comming from the steering wheel. Fluid level was good and it didnt matter if the car was moving or not. Took it to dealer and they replaced the rack and pinion under warranty. Seems to turn much easier now.
Old Sep 10, 2006 | 09:48 AM
frdtch05gt's Avatar
Mine makes a very loud squeal as well, it's going in tomorrow for a bunch of warranty work.
Old Sep 23, 2006 | 05:52 PM
frdtch05gt's Avatar
The noise in mine is gone, dealer replaced the steering rack.
ricky1728
Feb 11, 2016 07:25 PM
OneCoolGT
Dec 10, 2015 07:55 PM
JonathonK
Sep 24, 2015 06:31 PM
y5e06
Sep 21, 2015 08:05 AM
