side rear marker lights
Old Jan 2, 2006 | 09:42 PM
GottaHaveIt's Avatar
So I'm washing my car and turn the lights on while towel drying and notice on the passenger rear marker light out, so I go in the trunk to find it and there is a little box with four corner push clips that only allow it into the wheel weld but not onough to get at it ooy ! would anyone happen to have a scematic on a sheet to see it.
Old Jan 3, 2006 | 04:05 AM
IsaaX's Avatar
They are easy to pop out from the outside of the car. I had to replace mine after I ran over something which smacked the lense and broke it. The light assembly is mounted to the bumper by two pressure clips that are molded onto the light housing. You can remove the light by pushing it to one side then lifting it out. After that you will have access to the socket for the bulb.
Old Jan 3, 2006 | 06:26 PM
thanks but when I took it in to ask today its all covered under my warrenty and just like you said but pry the futhest back of the car end out first as that is where the clip is that holds it in place, the little box thingys are vents for the trunk compartment . beets drilling a hole ar ar.
Ecostang
Nov 3, 2022 08:50 PM
Diode Dynamics
Jun 12, 2018 03:26 PM
RRRoamer
Jan 19, 2017 05:27 PM
Sylvain
Jul 16, 2015 04:34 PM
