SHR louvers - paint??
I want to like the SHR louvers import to Germany ready-painted.
http://silverhorseracing.com/cart.ph...ategory_id=255
Is the paint quality good and ready for installation or should I rather let the painting in Germany? I want it looking good and hope for a response from you.
legacy Tms Member
painting is a royal pain...my first set took me about 5 hours to paint, was happy with the way they turned out, but i didnt use adhesion promoter as per instructions, they came loose the first hot sunny day, i decided to buff them while they were out and burned thru the paint...
I reordered prepaints and the proper adhesion promoter from Marcello, put them in and no regrets 6 yrs later the prepaints are very good, after doing so many sets, they surely know better than anyone about painting these...I saw a couple that guys had done by bodyshops, you could tell they had a hard time...hard to describe how difficult painting is, but masking a clean edge down in a hole, worse yet spraying down in a hole, with paint wanting to blow out of that hole, getting good coverage without a thick edge at the masking line...the prepaints have good match, good coverage and clean masked edges... a bodyshop doing these(unle$$ willing to $pend all day working on a couple plastic parts) will likely not get as good of a paintjob, just due to the experience that SHRs painters got after doing the job hundreds or thousands of times.
I'll eventually get a set for my 09 also, and will go prepaints again, for whatever thats worth...I had no idea how challenging painting these things would be.
ps- DONT FORGET TO USE THE ADHESION PROMOTER. the instructions are very clear, but still, i improvised...didnt have any, wanted to get them in that day, etc... just figured wiping the backside edge with laquer thinner would be fine for bonding...nope, urethane pulled clean away 6 months later. the adhesion promoter is like a molten/black primer look after you put it on- it melts way into the surface and gives great bite to the urethane- it wont let go
personally, i think all mustangs shoulda came with these- they add to the fastback look, visibility is almost unchanged, and IMO you wont find better folks to deal with than SHR
I lust for a M24
I ordered them unpainted the 1st time. I was never happy with what I got from a local shop who has an otherwise great reputation. I ended up selling them and buying a set of pre-paints like I should've done the first time. I don't think there are too many shops in the world with a higher quality standard than SHR. Order them pre-painted.
legacy Tms Member
beautiful car... and those louvers are still my favorite for changing the look of the car, ford shoulda made it that way
love the semigloss black on gray - goes great with your wheels too. bet you have envious Porsche owners looking closely when they see you on the road
"beautiful car... and those louvers are still my favorite for changing the look of the car, ford shoulda made it that way "
They did on the Cobra Jet
Mr. Sparkle
9/11/15 02:57 PM
