should i return car to stock tune for inspection.....
Old Jun 24, 2006 | 06:55 PM
WERKED 66's Avatar
just as the title says..i figured i should and drive it a bit so it learns stock tune again...was unsure if it would hurt my inspection at all.......mods feel free to move if not posted in correct spot........
Old Jun 24, 2006 | 07:58 PM
RaGsHoCkEy88's Avatar
hmm i dont think the actual tune will affect inspection at all. if u have mods, maybe. but otherwise i dont think u'd have a problem at all
Old Jun 24, 2006 | 08:03 PM
WERKED 66's Avatar
no mods just a tune
Old Jun 24, 2006 | 10:05 PM
karman's Avatar
Originally Posted by WERKED 66
no mods just a tune
Inspections for emissions are just that. If they connect to the OBDII they are looking for codes. If you don't have a check engine light...no codes and you are okay. A well tuned engine should mean better emissions.
Old Jun 25, 2006 | 08:34 AM
Sonic Boom NH's Avatar
Sometimes you can set a P1000 code which is:
P1000 - OBD-II Monitor Testing Incomplete
I have seen this happen with some Ford Lightning’s using Predator tunes so not sure if there is any issue with P1000 codes on the Mustang.
In any case that code will not set the check engine light but the inspection will pick it up and not be able to complete the inspection. They will generally tell you to drive it around for about 30 minutes and come back.
You can also get a P1000 code anytime you disconnect the battery so the inspector will most likely not know, if you have it, that it had anything to do with a tune.
Old Jun 25, 2006 | 08:42 AM
burningman's Avatar
Bow Chica Bow Wow
TMS Staff
try it as is if it fails..make it stock then go back and switch it back once you get home
Old Jun 25, 2006 | 08:54 AM
WERKED 66's Avatar
i think i am just going to go back to stock......then reflash when i am done...but i hate to waste the 93 in there...oh well.......
kylerohde
Jun 24, 2021 10:57 AM
Bullitt 3309
Aug 2, 2015 10:20 PM
Big-D
Jul 27, 2015 11:24 AM
Burnhaven
V6 Performance Mods
Jul 23, 2015 11:57 AM
Sylvain
Jul 16, 2015 04:34 PM
