SERVICE ENGINE SOON LIGHT IS ON......
Old May 15, 2005 | 02:59 PM
sharkstang's Avatar
Well,
Eight hundred 800 mile and old nelly's service engine soon light is in 3-D. Any thoughts??????? :scratch:
Old May 15, 2005 | 03:02 PM
THRUST_'s Avatar
seems like a common problem because it is so sensitive. Some people said they had this problem because they didn't put there gas cap on tight enough
Edit: maybe not common, but you aren't the first
Old May 15, 2005 | 03:07 PM
sharkstang's Avatar
Checked that already. Seems to be driving OK but who knows. I guess its time for a checkup.
Old May 15, 2005 | 03:46 PM
Gene Jockey's Avatar
Mine came on, I had a cracked plug on #3. It certainly explained the choppiness at low RPMs I'd been meaning to take it in about.
Old May 15, 2005 | 04:12 PM
Mustang69-05's Avatar
Mine did the same thing..... Started fine, went to back out and started running rough.... Shut it down started it again and same thing, CEL on and just missing. Ended up being the coil over, which I figured it was. No big deal. They replaced that and the plug. Only took them a couple of hours to fix.
Old May 15, 2005 | 06:26 PM
chorpeac's Avatar
How can you even mention Lemon??? A Lemon is a vehicle with the same problem multiple times right? Since this is the first time you are reporting this....how can you imagine a lemon already?
Old May 15, 2005 | 06:54 PM
incorrigible's Avatar
Yes! A lemon, at least in California, is a car that has been in for service for the same problem more than three times. A check engine light coming on is hardly in the same category! With that said, I do understand being a little upset though.
Diode Dynamics
Jun 12, 2018 03:26 PM
Diode Dynamics
Feb 28, 2018 09:37 AM
jc46002003
Apr 15, 2016 03:00 PM
ssjbuu
Aug 28, 2015 08:55 AM
cloud9
GT350
Aug 18, 2015 01:34 PM
