Saleen HID Headlamp Kit
Old Jun 7, 2005 | 06:03 PM
Rick M's Avatar
Purchased HID Headlamp Kit direct from Saleen. Delivered price $1133.00. Kit consists of headlamp assemblies (DOT Approved). ballasts, wiring harness, fuses, and relays.
When I went through parts list the main harness was missing. Called Saleen and they overnighted the harness at no charge!
The kit isn't exactly plug and play. The front facia, wheel well covers, and upper facia cover have to be removed. Holes have to be drilled to mount the ballast and relays. No wires need to be cut/spliced. It took about 2 hours total to complete the install.
The kit is well made with stainless bolts/screws, and a quality harness. The light assemblies are stamped Ford/Sylvania as are the OEM assemblies. Aiming the lights was very easy as the adjustments are indentical.
Performance is fantastic! Driving with the low beams gives you the distance of normal high beam Halogens. The high function just adds to the low beam pattern, expanding the horizon upward. The two other things I noticed was a much wider horizontal beam with a more illumination directly in front fo the car. The light distribution was very uniform with no hot spots.
No, I dont' work for Saleen and yes, they are expensive. If you want quality and HID for the 05 Stang, this is the only current way to go.
Old Jun 8, 2005 | 02:44 PM
bpmurr's Avatar
Now if I only had $1133.00 to spend on this.....
How does it look with the fogs turned on at the same time? Does the contrast between the color of the bulbs in each unit make it look bad?
Old Jun 8, 2005 | 02:54 PM
Rick M's Avatar
The fogs don't help with the HIDs. Need to address this in the future.
Old Jun 8, 2005 | 03:30 PM
bpmurr's Avatar
Well from a looks standpoint when you look at the front of the car would it look funny to oncoming traffic?
Old Jun 9, 2005 | 12:33 PM
Rick M's Avatar
Well lts put it this way, two white torches left and right and two dim yellows in the middle. You will also notice the fog reflectors are not as shiny (rather dull) compared to the main headlights (stock or HID). I guess that has to do with suppliers and was not intentional with FordMoCo.
Old Jun 9, 2005 | 01:44 PM
bpmurr's Avatar
I think some Silverstars in those would help even out the look. I might order the Saleen HID kit next week.
Rick you wouldn't have happened to take any pictures? If so I'd love to see some.
Old Jun 9, 2005 | 08:02 PM
JustFord0099's Avatar
I would have waited till less expensive ones came out. there are plenty of quality companies that make HIDs..im not givin saleen my money for somthin thats going to be less expensive in a few months.
Old Jun 11, 2005 | 10:21 PM
Rick M's Avatar
If you go to the xlighting web site (Division of Sylvania) they are coming out with exactly the same 5 1/4 HID headlight which is in the Saleen kit. They will sell for $700 a pair, but you will have to do some very serious hacking. If you include the OEM style harness relays and fuses and the entire headlamp assemblies, the Kit is worth it. To get a feel for costs, price a OEM headlamp assembly from FORD parts. I suspose to save some money, you could always sell the old headlamp assenblies on E Bay or equivalent.
Old Jun 11, 2005 | 11:22 PM
harrier's Avatar
xsighting makes the Saleen HIDs. they referred me to Saleen to purchase them.
pics please, rick.
Old Jun 12, 2005 | 06:28 AM
WERKED 66's Avatar
you gotta post some pic`s rick......would love to see how they look...
Old Jun 12, 2005 | 07:50 AM
Rick M's Avatar
I will try to take some before next weekend
Old Jun 12, 2005 | 08:48 AM
Rick M's Avatar
Here are some Pics. The fogs now have Artic White bulbs in them.
[attachmentid=24138][attachmentid=24141][attachmentid=24139][attachmentid=24142]
Old Jun 12, 2005 | 09:13 AM
bpmurr's Avatar
They look nice, any chance for some night shots showing the front of the car and another showing the lighting from the drivers seat?
Old Jun 12, 2005 | 09:25 AM
WERKED 66's Avatar
that would be some good shot`s..... it would either make me buy it or not....
also it look like they connect to the fuse panel under the hood hu??????? that kit must really be plug and use.....
Old Jun 12, 2005 | 11:32 AM
Rick M's Avatar
I will try to get some night shots
Old Jun 12, 2005 | 08:55 PM
WERKED 66's Avatar
thanks rick
Old Jun 14, 2005 | 07:31 AM
Rondosa's Avatar
Meet Krissy, Our Star Racer
Does anyone know what Kelvin rating these are? 4300K maybe? They look fairly white - the fogs actually look much bluer, but it could be the angle.
I'm very very interested in these - I love HID kits (had them OEM in my last car and retrofitted them into my motorcycle). They'll probably come out to $1800CDN though :bang: ...for that money, I could get a pretty awesome suspension set-up!
Oh well...still curious about the K rating...
Cheers
Kris
Old Jun 14, 2005 | 02:05 PM
Rick M's Avatar
[attachmentid=24474]The bulbs and ballast are made by Osram (German Sylvania). The bulbs are latest DR 1 (Ignitor in base) with a color temperature of 4000 which gives off a diamond white light with no hint of blue. The fogs are 7000 and are definitely blue. To give you an idea of the beam distribution and color temperature, attached is a shot with low beams (no fogs) on a garage wall with the car several feet away.
$1200 is a lot to spend. Hope that helps.
Rick M
Old Jun 14, 2005 | 02:16 PM
Rondosa's Avatar
Rick M
thanks for the info!! I'm surprised about the 4000K, as the trend is heading closer to 5000K and 6000K for OEM applications. Also, never heard of this bulb type, I'll have to do a little googling.
thanks rick
Old Jun 14, 2005 | 07:22 PM
Rick M's Avatar
Sorry, the bulb is a D1R.
Rick M
