Rotor help
Old Aug 13, 2013 | 06:22 PM
05GT4.6's Avatar
Rotor help
Now, I'm only human. I don't know everything. That being said, is there anything I need to know about installing new rotors? Or is it as simple as taking the rotor off and putting the new ones on?
Old Aug 13, 2013 | 07:37 PM
Gigantor's Avatar
It's as simple as it seems. First you take off the calipers and brackets then there are what looks like washers on a couple of the studs. You take those off and the rotors come off. If they're frozen on try hitting them from behind with a hammer.
Old Aug 13, 2013 | 09:05 PM
houtex's Avatar
Like Alex said. Also, those washers are not required to be put back on. They were used in the factory to keep the rotors on during the assembly process. Since you'll be puttin' your wheels right back on, just toss them.
Old Aug 14, 2013 | 09:13 AM
05GT4.6's Avatar
Thank you so much guys.
Old Aug 15, 2013 | 07:18 AM
zipperhead's Avatar
Well almost.. Assume your replacing the pads. If so you will need a special tool to compress the rear calipers. Autozone is your friend as they have a lend a tool program
Old Aug 15, 2013 | 08:54 AM
05mu5tang's Avatar
Oh and dont forget to clean new rotors...lol they tend to come all oily... Use brake cleaner and some lint free rags to clean them up... Dont forget brake lube either...
Sep 16, 2015 06:44 PM
Joeywhat
Sep 6, 2015 08:09 AM
lowblustang00
Sep 5, 2015 12:18 PM
mrrooney
Jul 26, 2015 09:35 AM
