Redline Tuning hood strut install question
Old Jun 4, 2007 | 02:34 PM
DoctorQ's Avatar
Opted to go with Redline QuickLIFT (with rivets) vs. MRT to eliminate risk of misaligning hood. Now looking for any lessons learned during Redline strut install. I'll need to go out and snag a pop rivet gun (either a Pittsburgh @ Harborfreight or a Craftsman @ Sears). Never rivet'd before, so looking for any words of wisdom. Thx
Old Jun 4, 2007 | 02:39 PM
manystangs's Avatar
When riveting, don't press down too hard. If you do, when the rivet "pops" you will gouge your paint!
Michael
Old Jun 4, 2007 | 02:57 PM
RobK's Avatar
Practice on something other than the car until you get the feel for it. Generally speaking the force required increases exponentially as you near the point of shearing the shaft and setting the rivet. It's at that point that it's easy for the tool to jump or go in a direction you didn't intend. Try it and you'll see what I mean.
Old Jun 4, 2007 | 05:51 PM
jadeuel's Avatar
+1 on the possibility of scratching...these are some fairly stout rivets in the kit. I painted my mounting plates to match and made some faint little scratches on 2 of the brackets you may want to apply some painters tape to the local area just in case...it can't hurt and you are supposed to have some out for the first few steps anyway. But mine have been on for over a year and I couldn't be happier with them.
Old Jun 4, 2007 | 06:03 PM
05fordgt's Avatar
A few tips for you. When you get the drill bit out, wrap ALOT of electrical tape around the bit, with just about 1/4" showing, so when you do go through the hood, you won't go all the way through, and pierce the top.
Second, get yourself a large old blanket and cover the ENTIRE engine compartment! You will thank me later, after you see all the shaving coming down from the hood. Remember, the hood is aluminum, and a magnet won't pick them up. You can use the magnet for when you have to drill into the inner fender, where the bottom mounts go. And when your done drilling the holes, remember to touch up the area where you drilled with paint. Its an easy install, and you can say goodbye to the prop-rod forever!!!
Old Jun 4, 2007 | 06:07 PM
GRAYPNY's Avatar
After all of that I'm sure glad I went with the MRT struts.
Old Jun 4, 2007 | 06:20 PM
What's so special about the Redline struts?
Old Jun 4, 2007 | 08:35 PM
DoctorQ's Avatar
Great input... Thx for the tips. on the painters tape & on the drill bit tape & alum shavings tip. You're so right... I never would have thought of alum shavings until they were falling all over the engine bay!
Why Redline? Initially I was thinking of the MRTs.. but have seen multiple posts about the risk of hood misalignment (all it takes is a 16th of a inch shift). Only negative I've seen with the Redlines are the drilling and riveting.
Old Jun 4, 2007 | 09:12 PM
RedDragon777's Avatar
measure, measure and measure again mine are off by a little but only i notice it. another thing is get some touch up paint cause you will need it and also the most important item you need is a center punch YOU WILL need it or else you will cause more damage drilling then you will riveting and blue painters tape and a sharpie for the measuring
Old Jun 4, 2007 | 09:16 PM
Boltzman's Avatar
And they get in your way when you lean into engine bay
Old Jun 4, 2007 | 09:21 PM
this is the kit you will more than likely be getting since the kit Jadeuel has has been discontinued and the one i bought is the new kit which looks alot better and is not so long, if your kit somes with 4 rivet brackets instead of 2 brakets and 2 ball joints then you can send it back to RedLine for their new kit
Old Jun 4, 2007 | 09:22 PM
the new design does not have that problem anymore
Old Jun 4, 2007 | 10:47 PM
Humboldt Stang's Avatar
MRT's and CDC's are ridiculously simple to install.
Did it myself in just a few minutes.
Old Jun 4, 2007 | 11:56 PM
07 HOSS Mustang's Avatar
CDCs use no rivets and install in 1/2 an hour. No risk of any damage........Use existing bolt holes too
07 HOSS
Old Jun 5, 2007 | 05:11 AM
05RedGT's Avatar
+1 on that!
Old Jun 5, 2007 | 06:49 AM
Fryguy's Avatar
I have the Redline and love them.
The MRT kit was not available back when I got mine, but that being said - the Redlines are nice. Just take your time - measure twice - drill once.
Old Jun 5, 2007 | 07:15 AM
jcthorne's Avatar
The redlines do not look like an aftermarket add on once installed. Sure they are a little more work, but the end result just looks far better. Also available in polished finish.
Old Jun 5, 2007 | 08:14 AM
Barricade's Avatar
After you drill be sure and use some touch up paint on the exposed metal hole.
Let it dry then install bracket and rivit in place.
Easy cheesy and function great.
Old Jun 5, 2007 | 09:40 PM
Boltzman's Avatar
Cool! are the 2 brackets riveting as well?
Old Jun 5, 2007 | 10:11 PM
the top two brackets have rivets but the bottem two are a drilled in ball joint's so all you have to do is pop the strut onto the ball and you are done
