Rear gear oil
Can you tell me what gear oil is needed for my 06GT? I used this stuff
http://www.autozone.com/greases-and-...oz-/977483_0_0 Do I need friction modifier? I think its already in there. Thanks for the help! |
Yep, pretty sure that is the right stuff.
Ford has changed their viscosity recommendation over the years, not sure why they did that. . . . IIRC it was 75W-110 in the past and then later raised to 90W-140. I guess either one is OK. It says it does not need the friction modifier, in other words it is already in there. I have seen conflicting opinions on this -- some say to add it anyway, some say don't. After you change it, do some tight figure eights in a parking lot to work it in to the clutch plates. If it chatters or binds, I think that means you need more friction modifier. |
Thanks Bert! I didn't do any tight turns but I will. I also hear a noise now when I am turning corners. Hard to explain...kind of a whiring <- not a werd
Originally Posted by Glenn
(Post 7016970)
