Rear end whine
Old Mar 4, 2007 | 06:15 PM
DB4180's Avatar
Rear end whine
Anyone with an 05-07 GT automatic experience a rear end whine? Thanx,DB
Old Mar 5, 2007 | 05:43 AM
yep I got it! A few people have had it fixed. I am almost getting sick of hearing it after 6k miles
Old Apr 1, 2007 | 10:08 AM
Vagrant Zero's Avatar
Just got my auto 07 GT, it has the whine as well. What's it from?
Old Apr 1, 2007 | 11:07 AM
mvon919's Avatar
SEARCH? There's TSB issued for this too, fORD will change your rear clutch packs... I got my '07 TSBd some time ago.
Old Apr 1, 2007 | 12:35 PM
kevinb120's Avatar
yup, just bring it in to the dealer.
Old Apr 1, 2007 | 04:07 PM
eci's Avatar
eci
DON'T bring it to the dealer and have the *inferior* clutch packs installed. Instead, just pump in 4 OZ of Ford XL-3 friction modifier to the rear end and problem = solved.
Old Apr 1, 2007 | 04:11 PM
Burke0011's Avatar
Big Falken Tires
And if the added modifier doesn't work (like happened with my car) trying to fix it, bring it in and have the TSB work done.
I am SO **** happy to have that noise gone while parking, slow turning in shopping mall parking lots, etc.....
Old Apr 1, 2007 | 09:41 PM
topkho's Avatar
I have the whine, too..
Where do you put the friction modifier ? Can anyone explain the process ?
Thanks.
Old Apr 1, 2007 | 11:19 PM
theedge67's Avatar
It goes in the rear end gear differential. The plug is on the front driver side of the diff. It's a metric size of some sort, just unscrew the plug and put in the bottle of friction modifier. The bottle is available at any Ford dealer for about $8.
Old Apr 2, 2007 | 03:06 AM
metroplex's Avatar
If you take it into the dealer, there's a good chance they will take out the carbon fiber clutches (OEM on 03-04 Cobra and 07 GT500) and replace it with the standard B clutches (used in almost every 86-up 8.8" Traction-Lok).
Old Apr 2, 2007 | 08:08 AM
topkho's Avatar
How to access the read end gear differential ? Is it under the car or under the hood ? Is it easy to access ?
I searched and could not find clear guidance... thanks guys !!!
Old Apr 2, 2007 | 08:53 AM
06GT4RAD's Avatar
OK do not take this the wrong way. But based on your reply I would suggest you not attempt any type of repair on your car and take it to a pro or have someone who knows show you and teach you what to do.
Richard
Old Apr 2, 2007 | 11:14 AM
kevinb120's Avatar
I agree. Do the wrong thing and if things go wrong the dealer will have the fluid analyzed for a warranty claim.
Old Apr 2, 2007 | 11:57 AM
mvon919's Avatar
Oh man... just don't do anything under hood/car. Gas tank is outside the car on left rear fender...
Old Apr 2, 2007 | 04:55 PM
ArchieSVT's Avatar
Which is better? Our car has the wine and I was wondering what it was. I will probably just add the friction modifier and see how that goes.
Old Apr 2, 2007 | 05:01 PM
theedge67's Avatar
The carbon fiber clutches are better. Try the f/m it seems to help in about 90% of the time, and it is cheap and easy.
Old Apr 2, 2007 | 05:22 PM
metroplex's Avatar
Steve is correct! The carbon fiber clutches were designed for the 03-04 SVT Cobra, and are used on the 07 GT500.
Old Apr 2, 2007 | 09:48 PM
06GT4RAD's Avatar
I have found over the years that Redline Gear Oil in the 75w140 will also help to solve the noise issue with the clutch packs it already contains friction modifier. Also gear whine and clutch pack chatter are two separate issues. Gear Whine is usually prevalent at driving speeds while the chatter is low speed sharp turns usually.
Richard
Old Apr 3, 2007 | 09:22 AM
its in your console. You have to cut a small hole in the bottom of it. Then use a right angled screwdriver to access to prop rod for the rear diff
Old Apr 3, 2007 | 10:43 AM
PlayMisty's Avatar
Probably worth adjusting the kanooter valve and oiling the tyre grommets while you are in there.
