Raxiom Headlights
Raxiom Headlights
My son has a 2009 45th Edition Mustang and he purchased a set of the Raxiom headlights, only to find out once he recieved them they would not fit his car. The reason was because his car came standard with HID headlights and the plug is different. Is there a way to fix this problem or is he not going to be able to use the headlights? Any help would be appreciated.
The way to fix this problem would be to just send them back to AM..
Being as the plugs are different and won't fit, he's not going to be able to use them anyhow.. So he just might as well send them back to AM and get OEM replacements from Ford instead
wanted33 (3/2/17)
Just Plain Rude!
Can it be made to work? Sure. But if he didn't see this complication coming ahead of time, then this is not a problem that I would recommend trying to resolve yourself.
As others already mentioned, the lighting of the Raxiom lights (with halogen bulbs) will be poor...very poor compared to his stock HID lights.
If you really want to make them work with HID bulbs, it can be done. The light output will be decent, and certainly better than halogen bulbs. BUT the distribution of the light will still not be very good, since the projectors are garbage.
Having said all that...I would return them and stick with the stock setup.
