Question about the strut popping noise
my car just started maknig a popping noise but i only notice it when the car is not moving and i turn the wheel from one side to the other side on both extremeities. i hear a popping noise sometimes and others a popping sorta grinding noise. is this the TSB?
Yeah here is the TSB
TSB 05-9-11
FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT - VEHICLES BUILT BEFORE 4/8/2005
Publication Date: April 27, 2005
FORD: 2005 Mustang
ISSUE:
Some 2005 Mustang vehicles built before 4/8/2005 may exhibit an intermittent popping noise from the front of the vehicle while turning left or right. The noise will typically occur during low speed maneuvers and may occur multiple times while turning.
ACTION:
On both sides of the vehicle, install a revised upper strut bearing assembly. If the vehicle was built before February, 2005 it may also be necessary to install a lower spring seat isolator if one is not already present. Refer to the following Service Procedure.
SERVICE PROCEDURE
Remove the strut and spring assembly. Refer to Workshop Manual Section 204-01.
Disassemble the strut and spring assembly.
If the springs do not have a rubber isolator on the bottom spring coil, install isolators. Clean off any dirt prior to installing the isolator. The isolator should be installed 4" (100 mm) from the end of the coil (Figure 1).
Figure 1 - Article 05-9-11
Reassemble the strut and spring. During reassembly, make sure the lower spring coil is butted up against the lower spring seat on the strut and the upper spring coil is butted up against the upper bearing assembly.
NOTE: INSTALL ALL NEW FASTENERS DURING REASSEMBLY.
NOTE: VEHICLE ALIGNMENT IS NOT REQUIRED AFTER THIS REPAIR.
PART NUMBER PART NAME
5R3Z-18183-A Strut Mount (Bearing)
5R3Z-5l302-A Spring Isolator
W520215S440 Strut Upper Nut
N807144S440 Stabilizer Bar Nut
W520112S440 Strut To Body Nuts
W711091S900 Strut Bolt Nuts
W709870S439 Strut Bolts
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
050911A 2005 Mustang Install A Revised Upper Strut Bearing Assembly And A Lower Spring Seat Isolator On Both Front Struts (Do Not Use With 18124A, 18124AT, 5310A, 5310AT, 3455A, 3455AT) 1.5 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
18183 42
TSB 05-9-11
FORD: 2005 Mustang
ISSUE:
ACTION:
SERVICE PROCEDURE
WARRANTY STATUS:
DEALER CODING
18183 42
I also had the strut poping at low speed turns(parking).
Then I installed the STEEDA springs and transfered the strut mount.
It has been 1k miles and no noise yet ?????
I kept the mounts in the same mount hole position.
FYI , I didn't have a camber problem at the alignment rack.
whowasthat
9/3/15 08:48 PM
