question about Powered by Ford plenum cover
Old Sep 1, 2006 | 12:32 AM
jenks's Avatar
what size of nut do i need for the new throttle body studs? i ordered from CJ pony parts and they had the studs but not nuts for them. Also does the back part of the cover just slide over those bolts or do i need to take them off and put the bolt on top of the cover? thanks for any help!
Old Sep 1, 2006 | 09:50 AM
delz05's Avatar
Back of cover slips over post, them wire harness clips on top...as for nuts bring them to your local hardware store to match, but I believe they are 6mm. Hope this helps out.
Old Sep 1, 2006 | 11:50 AM
bigplayrayr's Avatar
You will need a M5-.8 flange nut. If you can't get a flange nut, just use a washer.
I double checked. I had 2 extra studs. I work in fastener sales so, I checked on my bolt gauge
Old Sep 1, 2006 | 11:54 AM
racerx's Avatar
Yup, that's exactly what I used. I got tired of waiting for them to come from the dealership on backorder. I just went to my local Taylor Do-It center and it fits fine.
Old Sep 3, 2006 | 11:45 AM
jenks's Avatar
thanks for the help guys, got some 6mm nuts and washers and they worked perfect.
Jim74656
May 1, 2023 02:15 AM
Ecostang
Nov 3, 2022 08:50 PM
Diode Dynamics
Jun 12, 2018 03:26 PM
AMWill
Jul 20, 2015 08:40 AM
DerekShiekhi
Jul 14, 2015 10:32 PM
