Pull to one side while braking?
Old Mar 18, 2007 | 02:05 PM
metroplex's Avatar
While braking, I noticed the Stang pulling to one side. I haven't driven it for awhile so I was wondering if it was just the rust on the brake rotors (which should have been totally cleared from normal braking) or if I need to worry about the parking brakes.
Is this a common problem with S197s? I know it is common on Crown Vics in the rain.
Old Mar 18, 2007 | 02:24 PM
DynamicmustangGT's Avatar
I have not noticed any side ways braking, Mine is never out in the rain/snow though
Old Mar 18, 2007 | 03:01 PM
Robbieg's Avatar
I just noticed for the first time yesterday for a short time they pulled to the right. It only lasted for one short trip in town one way and then it was fine. I know in my case it was not parking break related because it was coming from the front brakes.
Old Mar 18, 2007 | 03:09 PM
screamingGT's Avatar
It does it to me. 40 % of the time.
Old Mar 18, 2007 | 03:32 PM
Robbieg's Avatar
I would definitely take it in for service if it does it that much. How many miles on it?
Old Mar 18, 2007 | 04:08 PM
metroplex's Avatar
Mine has been 100% garaged and the only rust on the rotors came from the moisture condensing in the garage.
Old Mar 18, 2007 | 07:18 PM
RadBOSS's Avatar
Rotor rust comes off pretty quickly because they are in constant contact.
Checked tire pressures?
Pads are not worn out?
If you have caster differential side to side (factory set up), that will have some influence. A performance alignment would be symmetrical caster and camber.
Was the road you were on very flat or crowned?
Old Mar 18, 2007 | 07:50 PM
metroplex's Avatar
Tire pressure was even across the board. Rotors and pads are brand new. The wheel alignment was done at the factory. The road was very flat and the Stang normally never pulled to one side during hard braking. It may have something to do with storing the car in the garage for the winter?
Old Mar 18, 2007 | 08:56 PM
I-70 west's Avatar
Mine pulls to the left only at slow speeds, Not a big concern.
I just did my own brake inspection, didn`t find anything !
Old Mar 19, 2007 | 01:30 PM
Little Black Pony's Avatar
Check Your Rear Rotors For Wear
I had a similar issue. My Stang would intermitently pull to the right when stopping. It wasn't uncontrolable, but you could feel it in the steering wheel ever so lightly.
Well, I took her into work cause the rear caliper would lock when it the temps went to freezing. I was under the assumption it was the frozen brake cable TSB. So, had our service dept take a look and turns out my right rear caliper was sticking but the cables and linkage were fine.
The sticking caliper was bad enough that it toasted my rear pads, rotor and cooked the brake fluid. It had nothing to do with the TSB at all -- I just had a bad caliper on the right side. After the caliper and rotor were replaced my stang stops like normal again.
My suggestion is to check your rear rotors for abnormal wear marks and see if your pad thickness is the same side to side. Also, check the color of your brake fluid. If it isn't clear pee yellow then you fluid is getting cooked.
Oh, this was covered by warranty as it was a faulty part. Hope it isn't a common issue.
Old Mar 19, 2007 | 10:54 PM
Centurion96's Avatar
First let me say it sounds like a sticking caliper piston. If Ford still uses phenolic caliper pistons then it is a given as these thing would stick all the time. The metal pistons were a little better but on the trucks I've seen the metal ones stick if they were not used for several weeks.
Form the rocket ranch
BB
Semper Fi
Old Mar 20, 2007 | 05:53 AM
metroplex's Avatar
How do I make it un-stick?
Old Mar 20, 2007 | 10:36 AM
RobK's Avatar
How many miles on the car now, and how long did it sit? This may sound crazy, but having worked on BMWs so much, I've gotten used to flushing my brake fluid every two years. Since it's hydroscopic (absorbs water) it can lead to sludge and corrosion in the system. While it generally takes a long to really see the ill effects, it's cheap enough that it's no big deal. In fact, I actually use Ford Racing fluid in all of my street cars. You'll notice over time how the fluid tends to darken as it ages and takes on water.
I'm not sure if the Mustang has floating or fixed calipers (still waiting for my car!) but if they're floating there is a chance the slide pins might be a bit gummed up and not allowing the caliper to move freely as it should. Cleaning and lubing the caliper pins is the most overlooked part of a brake job bar none. I'm not sure why so many shops ignore it but it leads to poor performance and uneven pad wear.
Old Mar 20, 2007 | 08:30 PM
ford4v429's Avatar
legacy Tms Member
something Ive often wondered about- when detailing what happens if tire cleaner(often has silicones) gets on the outside rotor face? I'm always careful with mine, but Ive seen folks spray crap on everything...I would sure think that could mess up brakes at least for a while...
Old Mar 20, 2007 | 09:43 PM
RadBOSS's Avatar
These are floating calipers. A hung up slider pin as suggested above may be the problem. They should be well lubricated and shaft seal in good condition (not torn or cracked). Might try checking that. I would suspect that before any piston hang.
Old Mar 20, 2007 | 11:05 PM
I learn something every day on these forums. Since I haven't as much as waved a wrench at my new 07 I was unaware of it having floating calipers. I'll have to check them out when I paint them.
metroplex - Everything I wrench on is at least 9 years old and has at least 140K miles on it. when it came to calipers I learned early on that even though I could rebuild them, I had a lot less aggrivation in just replacing them. I would balance out the frustration factor and time against the replacement cost and in the case of brake calipers replacement won out.
BB
Semper Fi
Old Mar 21, 2007 | 02:07 PM
RobK's Avatar
Thanks for the confirmation that they're floating. (I'm still waiting for my car!) It's amazing how many cars I've touched over the years with pins that barely move or are completely frozen. When taking them apart to lube them it's pretty amazing how badly they can get scored and generally chewed up. Even if the seals do look OK, you still need to stay on top of lubing them. Your pads and rotors will last much longer as well!
Old Mar 21, 2007 | 03:17 PM
9,7XX
It only does it when I'm going under like 5mph. Say I'm going into the turn lane at a light, right before I stop. The car will pull hard to the left...
Old Mar 21, 2007 | 03:21 PM
RobK's Avatar
9,7XX
Does it happen all the time or on certain roads? I ask because a rutted road can definitely cause pulling issues, especially at low speeds and while braking. It's usually worse with big tires, but I see your car is 99.9% pure so I hadn't posted this before.
Old Mar 21, 2007 | 03:31 PM
yeah..it does it all the time. well not all the time. but it doesn't matter what road.
