Propane injection?
Old Nov 25, 2005 | 09:25 AM
TorqueIT's Avatar
Just picked up the latest rag of Mustang 5.0 showcasing a Mustang with Propane injection as its main source of fuel.
I thought it interesting even though I wondered why someone would do that for anything other than a fleet vehicle.
Then there was mention that propane has an octane rating of 100-115!!!
Holy crapolla! Now this perked my ears!
Has anyone got any information on places that do conversions such as this in the states? (This guys Stang was from Canada, along with the facility that did the conversion).
I'd like to do a little more research into this, but am not sure where I should go???
Old Nov 25, 2005 | 09:36 AM
slammer223's Avatar
I just did a google search for "propane injection" and most returns were regarding diesel engines. Googling "propane automotive fuel" came back with a lot of hits that you might want to investigate.
Old Nov 25, 2005 | 10:15 AM
TorqueIT's Avatar
I shall Google away!
Thanks for the info!
Old Nov 26, 2005 | 01:00 PM
maniak's Avatar
Here is some quick/dirty info about running propane..
1) Propane has less BTUs than gasoline (gallon per gallon)
2) Propane has a higher Octane.. This means if you have a propane only vehicle you can increase the compression or timing to make up for the loss in BTUs
3) Propane burns cleaner (oil/engine are cleaner)
4) Propane is normally cheaper (since gas hit $2/gallon).. Out here, Propane has hit a high of $1.49.. Its $2.50 delivered to the house out here (and thats into boonies)
5) Propane tanks aren't the same shapes as a normal fuel tank so its harder to fit into a vehicle (for conversion).. for SUV/mini vans there are tanks that are shaped like a spare tire (for use under the vehicle)
6) With propane it is always full service.. They fill your tank for you.. This could be nice, but can also be a pain since they don't usually rush to fill a propane tank.
We looked at the propane conversion a few years ago when arizona gave great tax breaks for doing it. Our problem was that you shouldn't convert an old vehicle (we had 200k miles on the truck by then).. and if we wanted to run dual fuel we would lose 10-20% mileage when on propane (since less btus' and we can't change the compression on the fly).
~Mark
Old Aug 24, 2006 | 09:08 PM
FireFighterHill's Avatar
Ford made a Mustang back in the 90s I believe that made like 600hp and ran on gas/alcohol/propane. I believe they made it just to show you could get great performance on alternative fuels.
Old Aug 25, 2006 | 12:42 AM
jenks's Avatar
i know a guy i use to go to high school with that had a Mitsubishi 3000GT that had a propane injection set-up kinda like nitrous(not running alone on propane like you were talking about but similar). supposedly this doesn't get you as much as nitrous, but is easlier on the engine.
Old Aug 25, 2006 | 07:53 AM
TakeOffStang's Avatar
www.qtww.com
Some amazing technology here!
Old Aug 25, 2006 | 12:56 PM
MustangGuy's Avatar
This will make Hank Hill, Assistant manager of Strickland Propane, seller of propane and propane accessories, very happy
Old Sep 3, 2006 | 08:30 AM
UK pony's Avatar
In England a lot of use convert our cars to run on propane LPG we call it. With our gas (petrol) prices at $7.50 per gallon propane is only $2.75!!
Old Sep 3, 2006 | 09:24 AM
korinwoodo's Avatar
I saw a Chevy Avalanche on the road the other day advertising porpane conversions. Can't remember the name of the company though. Looked local.
Old Sep 13, 2006 | 07:18 AM
Shotokan1509's Avatar
Neighbor has it on his 80's Dodge pick-up. He converted because he used to be part owner of a propane business, so advertising the usefulness and getting basically free fuel. It runs well, but there is a tank in the bed that takes up some space. He did not convert his newer Dodge.
Ecostang
Nov 3, 2022 08:50 PM
TMSBrad
Apr 14, 2006 08:47 PM
Fordracing200
Off-Topic Chatter
Dec 3, 2005 08:25 PM
icemant180
Nov 12, 2004 09:09 PM
