Passenger door doesnt trigger power window or interior lights
Old Mar 4, 2022 | 05:27 PM
kevint's Avatar
My biggest irritation is that when the passenger door is opned nothing happens.
The window is supposed to go down slightly and then go back up when its closed and it doesnt.
Also the interior light doesnt go on.
Not sure what is causing this..... or even where to start troubleshooting,
I was hoping it may be something simple like a fuse, The passenger door works perfectly.
Are the 2 doors on diffrerent fuses?
I am comfirtable taking the panels off and am willing to try anything to pinpoint the problem...
Has anyone else here experienced this?
Old Mar 4, 2022 | 06:04 PM
houtex's Avatar
Welcome to the forums!
Having done the driver's side on Awesome I'm familiar with the why of this. The switch that says "door open/not" is in the latch on the passenger side, and the entire latch must be fully replaced with a new one. It will come with a new lock actuator as well, or did last I checked. Get the actual Ford part.
I'm sure that's not what you wanna hear, but it's the most likely thing. The other thing is the wiring between the latch and the body control module in the passenger kick panel, or the body control module itself has corroded in a way that's unlucky. You'll want to get the shop manual and do proper diagnostics, but checking the wiring is probably in order. May be as 'simple' as taking the door panel off, getting in there and disconnecting the latch connector for the switch, and jumpering it to see what happens.
Hope that helps!
Old Mar 5, 2022 | 03:07 PM
m05fastbackGT's Avatar
This
tang65c
Jul 12, 2012 06:25 PM
Spider
2007-2009 Shelby GT500
Jan 29, 2008 08:38 AM
VVVROOM
05-09 Interior and Audio Mods
Jan 18, 2008 10:37 AM
metroplex
Nov 27, 2006 04:53 AM
Louie
Oct 26, 2005 09:07 PM
