Oops, put in 87 but I have 91 bama tune
Old Jul 22, 2007 | 08:46 PM
King Taco's Avatar
I accidently put in a little bit of 87 but i am running the
91 bama torque tune right now. Am i gonna have a big problem now...
Old Jul 22, 2007 | 09:00 PM
CannonBaller's Avatar
Try one of these:
1) put in an 87 tune
2) Retard the timing by 4 degress on 91 tune
3) Put in a HIGH octane booster.
ANd which ever option you choose. Stay under 3000 rpm and accelerate slowly.
THen fill up with the highest octane you can get.
Old Jul 22, 2007 | 09:13 PM
SixtySix's Avatar
DO NOT EVER put Octane booster in your tank. You'll foul your plugs, and end up replacing them.
Just switch tunes or retard your timing, no biggie.
Old Jul 22, 2007 | 09:21 PM
King Taco's Avatar
well, I had less than a quarter tank of 91 and then put in 87 (less than 2 dollars worth) and then immediately stopped and filled up w/ 91 again. If I change the tune, how long will I know to run the 87 and switch back to 91? thanks for the quick responses...
Old Jul 22, 2007 | 09:59 PM
bored out's Avatar
You could run it for a tank full or two of 91 to be safe.
Old Jul 23, 2007 | 12:45 AM
theedge67's Avatar
I wouldn't even switch the tune personally. If you only put $2 worth, that is under 1 gallon. That would make the average octane rating of your tank like 90.7 or something. Don't worry about it. If you hear some knocking, just back off the throttle a little. Once you fill it back up it will be good as new.
Old Jul 23, 2007 | 02:06 AM
mustang_lurkers's Avatar
Why not just syphon the tank and fill back up with 93 octane? Put the syphoned gas into another vehicle. That is what I would do.
Old Jul 23, 2007 | 09:52 AM
LEO_06GT's Avatar
Why can't you just flash back to stock??
Old Jul 23, 2007 | 10:39 AM
King Taco's Avatar
Hmm well I didnt think of doing that, but I have a JLT intake, will that make a difference
Old Jul 23, 2007 | 10:45 AM
RobK's Avatar
You'd be fine even if you did a full tank of 87 if you took it easy. With $2 worth don't sweat it.
AnotherMustangMan's Avatar
Cam Tease
Dude,you're fine. Even if you filled the entire tank with 87, worst case scenario: the computer would compensate timing for you, thus losing a few (10ish) hp. 39/40ths of your tank is filled with the right caliber dino juice. Worst case scenario: nothing will happen.
Old Jul 23, 2007 | 10:59 AM
RobK's Avatar
The timing adjustment may or may not take place with an aftermarket tune. It depends on the diligence of the tuner. But you could always compensate with your right foot if you DID get pinging. As stated, the amount is so small it's an absolute non-issue.
Old Jul 23, 2007 | 11:10 AM
King Taco's Avatar
Very informative thanks ppl.
Old Jul 23, 2007 | 11:34 AM
kevinb120's Avatar
Ditto, for that little(not even a gallon), no worries
Old Jul 23, 2007 | 11:59 AM
For you King Taco for pushing that 87 button...
Like other said, don't sweat it.
Old Jul 23, 2007 | 12:07 PM
King Taco's Avatar
hahahaha, well, i was like and when i did it
Old Jul 23, 2007 | 01:01 PM
slipnotovk's Avatar
i once put 87 in my bike when it takes 91, ran like SH*T until the 87 was out but after that i nvr had a problem. i think ull be in the clear, just dont go to heavy on that thoddle until u get that good ol' 91 back in there
Old Jul 23, 2007 | 01:25 PM
MELLOWYELLOW06's Avatar
Youll be fine, 2 dollars of gas wont change anything. Besides how accurate do you think some of these octane rating figures are coming from the gas stations. Im sure they play around a hair too. This is a sick world my friend.
Old Jul 23, 2007 | 11:26 PM
Shelby10''s Avatar
Your fine...just stay out of WOT until you use the gas
Old Jul 23, 2007 | 11:27 PM
Shelby10''s Avatar
Well check that... $2 worth didnt lower that much at all... dont go crazy with the car just in case... but really there are no worries
