OK I've had enough of this !
:notnice: I'm pretty much tired of the way my 05 falls on it's face whenever it feels like doing it! You guys all know the drill, after coming to a stop, usually after a high speed cruise on the interstate, my Mustang starts to go, then falls on it's face only to recover very quickly. Now something is WRONG with these cars! Is FORD listening???? Doesn't matter if the traction control is on or not, it will do it without notice. As I said seems to pretty much be a given that after a run on the interstate, the next complete stop, it will fall on it's face when you TRY to move. Ford should know by now that this is a problem, and they should have a fix in the works. I call my dealer, and he says, Ford has nothing in the data base on this problem, WTF!!!! :bang: Do any of you folks have any info on this problem? Seems most of the time you folks know more about what is happening inside Ford than Ford does. Oh ya it's a V6 with auto, and traction control, other than this problem, I love this car!!!!!
The only TSB I've seen is the one that states loss of power.
The fix was something about getting the V8
kidding of course.
I honestly don't know what the problem is...I've never experienced it.
Have you had the computer reflashed at the dealership?
When was yours built?
etc
kidding of course.
etc
I've got a 454 Chevy in the garage, do you think that will help? Seriously though, I thought I read that the V8 also had a hesitation problem, No?Granted not ALL cars are having a problem, mine was built in late October
This a safety concern that does need to be addressed by Ford right away.
Originally posted by softbatch+May 8, 2005, 5:33 PM--><div class='quotetop'>QUOTE(softbatch @ May 8, 2005, 5:33 PM)</div><div class='quotemain'><!--QuoteBegin-05V6@May 8, 2005, 6:22 PM
[/b][/quote]
It is not really a hesitation. It is as if the engine shuts off for a split second and then cathes and takes off.
Mine did it today... only seems to do it when accelerating hard in a low gear with the TC on. It's like a carb hiccups when too much gas is poured in when you floor it. It is pretty annoying.
Originally posted by Fazm@May 8, 2005, 6:53 PM
Haven't noticed this in my car yet, but i drive a manual. Maybe its only autos that are affected?
Could it be the variable cam shaft sensor. When I first got my GT, I heard a clicking. in the engine. Dealer said it was variable cam shaft sensor and that Ford knew about it and was working on a solution.
Originally posted by Shifty@May 8, 2005, 7:24 PM
It's the trans taking too long to downshift.
ive had the same problem as well. does it after a drive on the interstate. once you stop at the exit ramp and go again it does it. i have a GT 5 spd, so its not just auto tranny related.
Originally posted by moze+May 8, 2005, 7:31 PM--><div class='quotetop'>QUOTE(moze @ May 8, 2005, 7:31 PM)</div><div class='quotemain'><!--QuoteBegin-Shifty@May 8, 2005, 7:24 PM
[/b][/quote]
I don't think it's the trans, the car accelerates normally for a split second, the engine doesn't sound labored. The accel from a dead stop starts fine, just as it usually does.....then the throttle snaps shuts....then it opens again just as fast and the accell continues. This fly by wire stuff is strange, try this, at speed put your car in neutral, you will see the engine RPM stay at the in gear value even though you have no throttle input. Now slowly apply brake, the engine rpm will drop with vehicle speed. This seems to be why the car seems to be in high gear when slowing to a stop, the enigne rpm doesn't decrease as it would with a standard throttle linkage setup. It's strange as heck, if you try to slow on the interstate, by removing your foot from the throttle pedal it will be a little time before you will feel the car decel. Don't know if you have the same observations in a manual trans car. The auto trans makes me wonder just who the heck is doing the driving......AC/DC anyone ......who made who....
Posting a message letting people know about a problem is a good idea in that it lets other owners know about problems to watch out for...but other then that it doesn't do you any good in fixing the problem by posting on the internet.
It's kind of like posting a message here when you have chest pain and asking us what the problem is when it's in your best interest to go the the hospital.
Originally posted by 05V6+May 8, 2005, 8:50 PM--><div class='quotetop'>QUOTE(05V6 @ May 8, 2005, 8:50 PM)</div><div class='quotemain'>
That's what if feels like to me. Like as you coast up to the stop it's still in a higher gear, goes to gas, trans isn't ready, engine has to "pause" and wait, trans down-shifts, engine goes.
[/b][/quote]
For all of you with auto trans, try this:
http://forums.bradbarnett.net/index.php?sh...ler%20300&st=40
Read post #41 and do what the guy suggests that he found in the Chrysler manual. I was having downshift uglies with my '05 GT and I did that - and all those downshift problems went away. It may not help but it certainly won't hurt, won't cost much nor take very long! And there's the outside chance it might help.
Good luck.
Thank you for starting this topic....
I have a GT manual... and it does the exact same thing.....
But not all the time... I've had the car for 8 months now and it's happened about a dozen times...
It really ticks me off.... I mean come on now... the motor is tried and true from the f150....
Not to jump on another "something is wrong" bandwagon, but this has happend to me a few times. Each time it was on a downshift and the engine seemed to miss or just die for a second. Has not happened since it has warmed up though...going to be asking dealer about this at the 15k service. I thought this was a pretty known issue with a tsb/fix already released?
