Non-IUP help
Old Mar 24, 2005 | 09:14 AM
gunk mudder's Avatar
I had two light come on this morning on the way to work, unfortunately I do not carry the owner's manual in my car. One was the ABS light and the other I think has to do with traction control (a car with squiggly lines under it). Can anyone confirm what the last one is?
Old Mar 24, 2005 | 09:21 AM
GhostTX's Avatar
If the ABS is on, it means there's a problem with the anti-lock brakes and you should have it checked out.
The car with squiggles is traction control. It only illuminates with the TCS is actively being used by the car.
I dunno...your ABS stopped working so TCS kicked in to make sure you keep control?
Edit: FYI, TMS has the Owners Manual in the 2005 Mustang Documents Section.
Old Mar 24, 2005 | 09:34 AM
SaleenPowr's Avatar
your car's goning to explode. GET OUT NOW!
jk. Get it checked out at your dealer.
Old Mar 24, 2005 | 10:12 AM
Thanks for the info....I was pretty sure the last was traction control, but I couldn't 'member for sure.
BTW...Even thought the TCS light is on; I know the system is not actually active....Especially on the I-state with cruise set at 70 and clear roads.
I will be taking it to the dealer tonight.
Old Mar 24, 2005 | 06:45 PM
BEACHBOY's Avatar
Jerry, keep us updated on what they tell you. See ya around..........
titanjc
05-09 Interior and Audio Mods
Feb 5, 2008 09:58 AM
SVTJayC
Mar 3, 2005 05:07 PM
78Mach1
Jan 19, 2005 07:43 PM
