Noise in dashboard
I have a '08 GT and when I turn the key on or off there is a clicking sound like an old electric clock ,coming from the dash behind the speedometer and gauges. It last only the gauges on the dash moving to the correct positions (fuel, oil temp, etc )than goes away and everything is normal until It go to start it up again. It does it only when I first turn the key on, no matter if it is cold or just turn it off and on again. Anyone out there know what it might be?
Didnt have it before. |
It's likely a door motor for the AC/heater unit. There's one behind the gauges on that side, then two others behind the glove box.
Blend door motor
The gauge stepper motors are slowly going bad. My 2006 does the same thing especially on shut down.
Originally Posted by roger blose
(Post 7020294)
I read "noise behind dash" and automatically thought "blend door motor", but if the clicking noise is behind the gauges, it's most likely a gauge motor like you said |
thats the sound
I thought that noise was normal. My car has always done that.
Originally Posted by VGMStudios
(Post 7020566)
Mine does the same and Ford said it's normal. |
(Post 7020566)
I just figured it's just the gears returning to zero. Much like an old rotary phone. |
Originally Posted by woody24
(Post 7020640)
Mine does that too, and has done it as long as I can remember in my '06.
