New 2005 Mustang GT - Results of code check for 'Check Engine' light
I took my '05 GT to the service dept this morning to determine out why the lamp had turned on.
The code check revealed that the ECU had detected a misfire in the 'B' and 'D' coil packs under deceleration. After consulting with Ford engineering, the tech concluded that there aren't any actual problems and says that Ford is aware of the issue. Ford says they have a new flash program in the works to fix this issue.
Those of you who've had the same light come on, please post the findings here. I'm curious to see if this turns out to be a widespread thing..
