Need Help ASAP!
Old Nov 19, 2005 | 02:25 PM
blaster199's Avatar
I Pulled my rear brake caliper and while ready to put it back on, the piston that presses on the brake pads is extended so it wont fit on until it can be pressed back in. How do I get it to go back in? Please help me so i can have my car back together!!
Old Nov 19, 2005 | 06:00 PM
fin1's Avatar
It's real easy. You need to rotate it back into the caliper with this tool:
http://www.mytoolstore.com/kd/kdbrak07.html
The one on the bottom is for the Ford rears. It usually can be found at your local auto store as well. The cube won't fit so make sure it's the one listed at the bottom. It attaches to your socket wrench.
Old Nov 22, 2005 | 09:27 AM
Stoenr's Avatar
We use an old brake pad and a large set plyers, to push the pistin(S) back in.
