More Battery Issues
My OEM battery gave up on me afew weeks ago and I bought a Optima yellow top. I went out to start the car today and it wouldn't crank enough to start and then went into click mode.
I still have a month warranty on the car but I'm afraid to take it to the dealer because of the UDP's. I figure they will tell me that's the reason I'm having issues.
There is something draining the battery or not charging it. Maybe my alternator is gone? Any ideas?
As I'm sure you know, alternators on these cars seem to fail like fourth graders on crack.
Unless by poor luck you got a crappy Optima, that's probably the issue. Get a volt meter and check the output voltage while the car is running, should be 13.8-14.2 plus have plenty of amperage. Out here in Indiana, most auto parts stores (Napa, Autozone, Reilly's, etc.) will check batteries and alternators for free.
How long did it sit since last time you drove it? If 4+ days, I'd suspect something is still drawing power and sapped the battery... if you had it out for a decent drive yesterday, I'd suspect it's the alternator. Jump it, and as Tom281 suggests, test with output voltage with a multimeter... if charging properly, you should be at or near 14volts.
Drove it last Saturday. I was just sitting in the car and after I shut the key off the Shaker 500 goes through weird nosies like it's trying to load CD's. I turn the radio off and then then when I put on key in the on position the radio comes on.
Sounds like something is still drawing power with ignition off... and/or not going to sleep as designed. Test for parasitic draw... there are a number of "how-to" links... here's one that's pretty simple:
http://www.wikihow.com/Find-a-Parasitic-Battery-Drain
If you have a basic multimeter, it can be set to test amperage. You'll need to charge up your battery first, then test. Once you have the multimeter in-line, and everything you know turned off in the car, start pulling fuses one-by-one and watch the draw. Start with the Shaker500 fuse first as that may be your culprit.
I /propose/ that Rich's Raptor Shift Light and two electric Sport-Comp Autometer gauges are wired to a 12v source that is hot all the time. If that is the case, could these three things draw down the battery in a week?
Also had an issue with my battery yesterday. I have allready replaced the battery so I dont have the crappy OEM battery any more. Ran the car last weekend so it sat for about a week went to take her out lastnight and "click click" dead battery. I put it on charge for a good hour or so and then she started right up. I may next time check my voltage now that I see you guys are talking about the alternator.
Is the alternator that weak on the S197? I've rarely heard of so many battery issues with other Fords. An alternator/regulator wouldn't cause a drained battery. A faulty regulator would result in a discharged battery while operating the vehicle while faulty diodes would result in a overcharge condition. Neither of these can discharge the battery unless the regulator was somehow so messed up that it was draining the battery.
An easy way to check the alternator is by hooking up a DC clamp ammeter to the positive battery cable with the engine running. If there's 15A-20A (no accessories on) going into the battery, then it's working fine. There should be additional current supplied to the battery based on demand since the alternator was designed to produce up to about 80% charging capacity at idle.
I suspect there are other electronic gremlins at fault:
1). Shaker amplifiers
2). Smart Junction Box
3). PCM
3). PCM
3). PCM
3). PCM
