Man Trans/clutch question
Old Feb 11, 2016 | 01:44 PM
UncleB's Avatar
Hey Folks
With the car stationary and engine running and with the manual trans in neutral and the clutch engaged (clutch pedal NOT on the floor), how much noise should be coming from the trans/clutch?
Absolutely quiet ?
Just a little "spinning" noise ?
Lots of noise ?
Old Feb 11, 2016 | 01:47 PM
mrkabc's Avatar
Hi UncleB!
You should not hear any noise in a perfect world. That being said, I have, for the last 50k miles or so, have heard a whirring noise that disappears when the clutch is pushed in.
118k on the clutch, hoping it's the throwout bearing and not input shaft bearings. I guess I'll find out this spring when I swap out the clutch.
Old Feb 11, 2016 | 02:49 PM
07 Boss's Avatar
Originally Posted by UncleB
Hey Folks
Absolutely quiet ?
Lots of noise ?
Little confused with your question. If you have the trans in neutral and the clutch engaged, the clutch is against the flywheel. As you push the pedal down the clutch should releasing the flywheel or disengaging. So if you have the pedal part way down and in neutral, how do you know the clutch is still engaged? Try doing it in gear so you know when the clutch is actually engaged. And you shouldn't have to push the pedal all the way to the floor to disengage the clutch.
Are you asking how far you need to push the pedal to disengage the clutch? Or are you asking if there should be a noise as you start pushing the pedal and start disengaging the clutch? Need a little more clarity on your question to help you.
Old Feb 11, 2016 | 03:00 PM
UncleB's Avatar
Not asking when the clutch should engage or disengage---just wanting to know how much noise (slight whining sound) should occur when the clutch is engaged and the trans is in neutral
Thanx
Old Feb 11, 2016 | 03:06 PM
07 Boss's Avatar
Thanx
Well it just got confusing when you mentioned pedal position. With the pedal up and the car in neutral you should have some noise as the transmission is spinning inside but it has no where to go (no output). There may be a rattle which is indicative of possibly a bad TOB, or there is a TSB on the separator plate in or around the bell housing that rattles or vibrates.
Old Feb 19, 2016 | 12:26 PM
texasgt/cs's Avatar
Originally Posted by mrkabc
Hi UncleB!
i just took mine to the stealership for the same issue, Slave Cylinder/ Throwout Bearing. $925.00. Enjoy.
Old Feb 19, 2016 | 12:35 PM
Buckshot Barry's Avatar
Just a little "spinning" noise from my 2007 v6 with T5 manual.
And that's the noise level from almost brand new, she has 849 miles.
Old Feb 19, 2016 | 07:30 PM
houtex's Avatar
'06 with TR6350. Clutch in, no noise. Clutch out in neutral, gentle whirring of the gears as they mesh and unmesh, spinning about with nowhere to deliver any power.
So a teensy bit of noticeable... well, sort of a low volume, barely there growling maybe?... is normal. Grinding or squealing or such is not.
Old Feb 21, 2016 | 08:47 AM
NC14GT's Avatar
Really quiet here with my '07 5 speed. I actually had to listen. Only have about 32,000 miles though and 90% highway.
Old Feb 21, 2016 | 01:24 PM
houtex's Avatar
Yeah, that's how it is on mine as well. Only notice it sometimes if at all. Although I do have 131000 on her so far, so maybe a teensy bit more than 'normal' is normal for her these days.
Mainly I hear it when she's standing beside a building, so I suppose I'm getting some sort of echo bounce from under the car, maybe.
Old Feb 24, 2016 | 11:47 AM
jt14894's Avatar
Don't hear any strange noises or whines on my 2005 GT. Been the same way since the first day I bought it new.
Old Feb 26, 2016 | 07:15 PM
UncleB, FWIW the V6 and V8 models have different manual transmissions.
Whatcha got?
May 23, 2016 02:54 PM
coryc1200
1994-2004 V-8
Feb 7, 2016 05:57 PM
Sylvain
Feb 7, 2016 01:51 PM
wiily_traps
1994-2004 V-8
Jan 26, 2016 07:44 PM
