Magnaflow exhaust question
Old Mar 30, 2005 | 07:02 AM
Barricade's Avatar
Thumbs down
Im putting on a Catback system and I have the car up about 3 feet in the back
and ramps in the front. I cant seem to get it out from the axel.
Its disconnected and the muffler is on the floor.
I just cant get the pipe out from around the axel.
Do you take off the tire to curl it out or how did you do it?
HELP....
I know.....put it in the ext mods section but I need an answer fast and some of you Catback people dont look in there.
By the way....my stripes turned out AWESOME!!!!!!!
Thanks!!!
Old Mar 30, 2005 | 07:13 AM
adrenalin's Avatar
Ya lost me somewhere. You say your muffler is on the floor. Did you disconnect the muffler from the connector pipe? I removed the mufflers, loosened the clamps at the H pipe and then removed the connector pipes with no problems.
Edit: I think you have things backwards. The back end should be on the ramps and your front end higher in the air. The connector pipes will easily remove from the axle but you need enough clearance for the pipe.
Old Mar 30, 2005 | 07:23 AM
Barricade's Avatar
Did you have it on a lift?
Old Mar 30, 2005 | 07:25 AM
adrenalin's Avatar
No, in my garage. Rear was on stands and front was jacked up as high as my floor jack would go. Just cleared it.
Old Mar 30, 2005 | 07:50 AM
Barricade's Avatar
Thanks!! I'll put the big jack on the front
Old Mar 30, 2005 | 08:15 AM
JohnnyZ's Avatar
everything is sectional
just losen all the blots at every section and it'll all slide apart.
takes about 15 minutes
Old Mar 30, 2005 | 08:28 AM
outdoorstom's Avatar
I'm not familiar with the technical term "blots".
Old Mar 30, 2005 | 08:54 AM
adrenalin's Avatar
Blots are a distant cousin to the bolts family. Just a little more rounded around the edges.
Johnny, he is not having problems with the bolts. The problem is he doesn't have enough clearance under the car to remove the pipe. Due to the angle he needs a close to 2 feet of clearance to get the pipes out of there.
Old Mar 30, 2005 | 09:21 AM
JohnnyZ's Avatar
see, thats what happens when I only read half of a post.
and yes, the blot is a circular head on a screw... AKA girl of ill reputed out screw, striped, oh-oh...ect...
Old Mar 30, 2005 | 09:48 AM
Barricade's Avatar
@#$%@# clearance!!!
When you were done did you disconnect the battery to reset and
recalibrate the computer to the new exhaust?
earl610
Sep 6, 2015 05:48 PM
Cdvision
Sep 5, 2015 05:22 PM
whowasthat
Sep 3, 2015 08:48 PM
