Loud Squeak/Squeal - What could this be?
Last night we were driving down the gravel road (1 mile of gravel road to get from our house to the highway) at around 10mph like usual (to keep gravel chips/rattles from developing) and I started hearing a noise which sounded a bit like metal grinding that was accomponied by a high pitched squeak.
At first I didnt know our car was making it because it came on so suddenly, but after stopping the car and realizing the noise stopped with it I turned arund immediately. On the way home the noise got worse.
While going home I made not of some things. The noise is not caused by me pushing or depressing on the break. It happens when driving in first, coasting in neutral, even coasting backwards with the car off, so it does not seem to be tied to the transmission, clutch or engine. It's certainly not belt whine.
Sounds like it's coming from the front driver side wheel but you know sometimes sounds are weird and don't come from where they seem.
What could this be? Is it possible that I got a gravel chunk caught up in my brake system somewhere, is it the wheel bearing, what? It seems to be getting worse as I drove it around our circle drive a bit this morning after rinsing the wheels off with water. The noise is quite awful and alarming, and it just came on out of the blue.
Would something like a wheel bearing take longer to effect?
It has me worried becuse just two days ago I had an elderly women scrape her bumper against the rear passenger side area of my car. There was no damage aside from black rubber from either her bumper and it all buffed out, b ut it seems like an awful coincience to me. Though how could this be related if it literally didnt even do enough damage to scrape the paint or bend the plastic...
Anyone have an ideas or similar experiences?
Oh, I't s a 2005 V6 vert 5 speed with only 3100 miles on it.
definately have a stone stuck in there like mentioned above. Not the first time someone posted this issue and definately not the first car to experience this. Time to remove your tires and find out which one has the problem.
Originally Posted by StangNut
Driver's side mirror maybe?
Mine squeaks/squeals anytime I'm on a bumpy road.
1 Post
Yes, remove the tire and look between the rotor sheild and the rotor, you will probably find a rock. I had it happen to me in the first month of owning mine (December 04) and I don't drive on gravel roads. It has never happened since.
Is there any way this could have damaged anything or need I worry about it? It was between the shield and the rotor just like you said.
1 Post
If it wasn't squeeling for more than a day or two I would think you are fine. Just feel the rotor with your finger and see if the rock wore a groove in the rotor.
Oh course you probably have the wheel back on now!
After all these years,
My C/T still sucks!
My C/T still sucks!
OW you too? WTH?
Mine fell out finally after about two days. Driving early last week was an embarassment.
Result: eleanor is no longer allowed on Non Paved roads.
Originally Posted by Jeffs05GT
Yep, found a little rock right in there.
Rando
8/25/21 11:12 AM
