Loss Of Power on Startup... Sometimes??
Old Mar 1, 2016 | 02:39 PM
gabbiekay's Avatar
Unhappy Loss Of Power on Startup... Sometimes??
About 2 months ago,
I have an after market auto start installed on my car. I started it and it revved high for a few seconds and then dropped to sputtering. If I let it sputter, the wrench light comes on and if it does it long enough it will throw an engine light. Usually on cold days.
Turn it off and back on, most of the time it will run fine then. Even the check engine light will disappear (strange) by itself later on in the day.
The code said it was the TPS. Last week, I was about 15 miles into my drive and the idle went so low the car started sputtering and wanting to die everytime I took my foot off of the accelerator. I replaced the TPS and Cleaned the Mass Air Flow Sensor. It ran like it was new. for 2 days.
Now it is back to sputtering when I turn it on. but it takes multiple times of turning it off and on for it to settle and run right.
Help??? I am at a loss right now as to what this would be.
Old Mar 1, 2016 | 03:05 PM
Paris MkVI's Avatar
Since it is your first post, welcome!
What model year and engine do you have? How many miles on the odometer? What routine maintenance has been done? Spark plug changes, etc.?
Old Mar 1, 2016 | 03:06 PM
07 Boss's Avatar
Have you cleaned the throttle body? Stock pcv system/
Old Mar 1, 2016 | 04:18 PM
gabbiekay's Avatar
Year - 2009
Engine - v6
Mileage - 127000
Regular oil changes....
Never had any problem.
Have changed battery and tps. That's it.
Old Mar 1, 2016 | 07:11 PM
What 07 Boss said! Remove it to clean it. It is something you can do yourself in about 30 minutes or so. Maybe a new air cleaner for good measure. Welcome to TMS
Old Mar 2, 2016 | 06:36 AM
05YellowGT's Avatar
If the remote start install tapped into the 5V reference system it can cause all kinds of weird problems.
badboyz1620
'10-14 Interior and Audio
Aug 12, 2018 11:54 AM
JohnnyMustang2
May 5, 2016 02:55 PM
puma1552
Feb 13, 2016 10:40 AM
coryc1200
1994-2004 V-8
Feb 7, 2016 05:57 PM
